There are two methods on how to transfer content between WP sites.
Method #1. Themler Export/Import plug-in.
The content importing feature is available in Themler versions later than v. 298.
Export Content with Theme
Export theme with "Include Content" option enabled:
Install theme on your WP in a usual way.
- Theme includes theme plugin "Themler-Core". This plugin processes shortcodes and now also imports/exports content.
Please activate this plug-in if it is disabled or not installed.
If you already have theme plugin installed and activated please update it via WP admin panel or by opening and saving theme in Themler. - Now you should see the Themler Tools menu in WP back-end.
Here you can import and export content. Please see below for more details.
Themler Tools
SETTINGS - On this tab you can choose the number of posts and pages that will be included into the theme exported with "Include Content" option enabled (by date updated):
EXPORT - On this tab you can export content only (posts, pages, menus and images) as separate ZIP archive (without theme).
IMPORT - On this tab you can import content from separate archive (see above) or import content included into the theme.
Import Content from ZIP (without theme):
Import Content from Theme:
NOTE: Joomla and WordPress content exported as separate ZIP has unified structure. Therefore it can be installed in both CMSs using theme plugins.
Method #2. Standard WordPress Export/Import plug-in.
Please refer to this article for more details.
There are two methods on how to transfer content between WP sites. ## Method #1. Themler Export/Import plug-in. The content importing feature is available in Themler versions later than v. 298. <div class="alert alert-warning"> <b>NOTE:</b> Themler exports only posts and pages with images, and WP menus (ALL menus available under WP Appearance >> Menus). It <b>does not include widgets.</b> </div> ### Export Content with Theme 1. Export theme with **"Include Content"** option enabled: !include-content.png! 2. [Install theme](page:3624) on your WP in a usual way. 3. Theme includes theme plugin **"Themler-Core"**. This plugin processes shortcodes and now also imports/exports content. Please activate this plug-in if it is disabled or not installed. If you already have theme plugin installed and activated please **update** it via WP admin panel or **by opening and saving theme in Themler**. 4. Now you should see the **Themler Tools** menu in WP back-end. Here you can import and export content. Please see below for more details. ### Themler Tools !themler-tools.png! **SETTINGS** - On this tab you can choose the number of posts and pages that will be included into the theme exported with "Include Content" option enabled (by **date updated**): !themler-tools-settings.png! **EXPORT** - On this tab you can export **content only** (posts, pages, menus and images) as separate ZIP archive (without theme). !themler-tools-export.png! **IMPORT** - On this tab you can import content from separate archive (see above) or import content included into the theme. **Import Content from ZIP (without theme):** !themler-tools-import-1.png! **Import Content from Theme:** !themler-tools-import-2.png! **NOTE: Joomla and WordPress content exported as separate ZIP has unified structure. Therefore it can be installed in both CMSs using theme plugins.** ## Method #2. Standard WordPress Export/Import plug-in. Please refer to [this article](page:6035) for more details.
