The Hover Box control creates a container with the hover effect.
The Hover Box control can be added under Insert >> Other.
All controls inside the Hover Box will be positioned relatively.
This control is similar to Layout Container - the main difference is that you can specify a different background and add controls for normal (Background Slide) and hovered (Hover Slide) states.
You may apply different motion effects for slide change.
Layout Container
###Summary
The **Hover Box** control creates a container with the hover effect.
###Usage
The **Hover Box** control can be added under **Insert** >> **Other**.
This control is similar to Layout Container - the main difference is that you can specify a different background and add controls for normal (*Background Slide*) and hovered (*Hover Slide*) states.
###Sample
!hover-box3.png!
###See Also
[Layout Container](page:4419)
