Improvements
Ability to free-position any control to any exact place you like. It means that if there is no appropriate d'n'd layout position for control the absolute d'n'd position will appear (just like in Slider or Container).
Split all Large Headers to Header section for All Templates and Intro section (usually with Slider) for Home Template only.
This behavior will be applied to newly added Large Header Sections on the Home template only.
Cross-template areas like Header, Footer, Sidebars are now accessible as Ribbon Tab for selected children controls:
Few options added to Header Area tab:
- Sticky (previously named ‘Fix on Scroll’) to stick Header position during page scrolling
- Homepage Style – allows to override fill, border and text properties for Home template (e.g. to make navbar transparent on Home page only) . It will be applied to single inner section or header Area itself. It is available on Home template only.
- Overlap Next Section – set
position:absoluteto Header Section to overlap next Section (it is some Intro section usually). It will be applied to single inner section or Header Area itself. It is available on Home template only.
Improved Backlinks control. Now it is possible to disable backlinks to CMS and Themler under the Home tab >> Settings.
Added option to add/remove Columns left and right margin:
Removed Canvas control. The Canvas control was merged with Layout Container control. Now there is single Container control which supports any type of positioning.
Improved Themler stability.
Fixes
- Fixed issue with positioning of Horizontal menu control after update (when it was impossible to click on menu items).
Fixed issue with links in WP. - Other minor fixes.
