- Reduced the time of saving themes up to 10x.
Note: Depending on the export type the time of saving themes will be reduced after re-saving or re-starting Themler.
Extensions
- Animations for Slider, on Hover, on Page Load/Scroll, etc.
- Advanced Shadow effects
- "Expand to bottom" extension to stick footer at bottom
- Style as "Balloon" with arrow
- Image to page Background
- and more
See complete list of Extensions here.
Layout mode which allows you to view the template structure:
More compacted/simple Options in UI
- Added option to Insert images/background images from URL
- Now Padding and Margin options are shown under the Arrange section
Added option to switch between BOXED/WIDE layout of the theme:
Syntax highlight for HTML/CSS + Fullscreen editing (press F11 to open editor, press Esc to close)
Frame Buttons for Link Navigation, Content Editing:
"Show On Template" dropdowns for Header/Footer/Sidebars:
Bugs fixed:
- Show browser's context menu when text editing
- No properties for Shopping Cart > Product Remove
Added new Layout control: Sidebars
Added RTL support for buttons in the Search and Newsletter(Magento and PrestaShop) controls
Added "Grid Padding" option under Settings tab to add Left and Right Padding to all content on the website:
Shopping Cart: fixed issue with inheritance styles of the default menu submenu by pop-up elements
- Fixed issue with Google Maps control after updating theme.
WordPress and WooCommerce
- Fixed issue with building links in Themler Preview
- Fixed issue with automatic aligning of the Shopping Cart pop-ups.
- Added Add To Wish List control for Products template
- Added Theme Configurator control
- Added Facebook Block control
### General
- Reduced the time of saving themes up to **10x**.
**Note:** Depending on the export type the time of saving themes will be reduced after re-saving or re-starting Themler.
### Extensions
- and more
See complete list of Extensions [here](page:8762).
![enter image description here][1]
### UI
- **Layout** mode which allows you to view the template structure:
!layout-view.png!
- More compacted/simple Options in UI
- Added option to switch between BOXED/WIDE layout of the theme:
!layout-switch.png!
- Syntax highlight for HTML/CSS + Fullscreen editing (press F11 to open editor, press Esc to close)
- Frame Buttons for Link Navigation, Content Editing:
!edit-link.png!
- "Show On Template" dropdowns for Header/Footer/Sidebars:
!show-hide.png!
- Bugs fixed:
### Controls
- Added new Layout control: [Sidebars](page:9037)
![enter image description here][2]
- Added RTL support for buttons in the Search and Newsletter(Magento and PrestaShop) controls
- Added **"Grid Padding"** option under Settings tab to add Left and Right Padding to all content on the website:
!grid-padding.png!
- Shopping Cart: fixed issue with inheritance styles of the default menu submenu by pop-up elements
### WordPress and WooCommerce
- Added [Custom Templates](page:9466) feature for WordPress and WooCommerce
![enter image description here][3]
- Fixed compatibility issue with **IVO Velden** widget.
- Removed ReadMore button for Out of Stock products in Product Details template
- Added **Up-Sells** and **Cross-Sells** widgets
### Joomla
### PrestaShop
- Added **Add To Wish List** control for Products template
- Added **Theme Configurator** control
- Added **Facebook Block** control
[1]: http://attachments.answers.billiondigital.com/976/1976/extensions.png
[2]: http://attachments.answers.billiondigital.com/970/1970/sidebars4.png
[3]: http://attachments.answers.billiondigital.com/997/1997/custom-templates2.png
