I'm looking for a Vertical Menu options, but the latest version of Themer I can not find that option.
No Submenu and Expanded, On hover, etc., I need those options.
It is present in the Vertical Menu tab >> Responsive >> Submenu.
http://answers.themler.com/articles/5109/vertical-menu
Styling for the Vertical Menu can be adjusted in PW >> Styles >> Vertical Menu.
The Vertical Menu should be added first in a CMS back-end so that it appears in the Themler preview. Once it is added, you can select and style this control by using Vertical Menu options is PW.
Using Levels options you can choose how the Vertical Menu subitems should be opened:
-No Submenu means that the subitems are not displayed.
-Expanded - all subitems are shown in the menu.
-On hover - on hover, a list of subitems is opened but the parent item page is not loaded.
-With Reload - on hover, a list of subitems and the parent item page are loaded.
I do not find the above options.
Thank You.
Hi, http://answers.themler.com/articles/5109/vertical-menu > Styling for the Vertical Menu can be adjusted in PW >> Styles >> Vertical Menu. The Vertical Menu should be added first in a CMS back-end so that it appears in the Themler preview. Once it is added, you can select and style this control by using Vertical Menu options is PW. Using Levels options you can choose how the Vertical Menu subitems should be opened: -No Submenu means that the subitems are not displayed. -Expanded - all subitems are shown in the menu. -On hover - on hover, a list of subitems is opened but the parent item page is not loaded. -With Reload - on hover, a list of subitems and the parent item page are loaded. I do not find the above options. Thank You.Hello,
We are sorry for the oudated information in the article. Currently the default behaviour for the Vertical Menu subitems is to pop-up when hovering the parent item and the options listed in the article are not present, only for the responsive menu.
Oh well, this option is responsive menu only, that’s too bad.
thank you,
Hi, Oh well, this option is responsive menu only, that’s too bad. thank you,Hello,
Yes, ithese settings are for Responsive Menu. Let us know if you need our further assistance.
How i can add multi-level menu?
In version 319 I could use Vertical menu with "Level" button. What I must do in v.349
there're nothing special there. Just add Vertical Menu control in HTML site.
However it acts like on screenshot (I mean expand bottom) only in Phone mode.
I hope the implementation of this option.
Hi, I hope the implementation of this option.Hello,
We have added it to our wishlist so that our developers consider adding it in future.
I hope that you realize it.
Hi, I hope that you realize it. Thank you,You are welcome! Please feel free to contact us in any other case.
