Quick Header image change by CMS user
len
len posted this 27 September 2016
In the standard Wordpress Twenty Sixteen (and earlier themes) have an option to add a number of header images from within the Wordrpess CMS in the theme options. This is really easy for a CMS end user to do, as it includes a crop feature. Images can be randomised so that on page loads one of the images is randomly selected.
There are answers to similar questions in this forum, with suggestions to use a widget and place an image there. end users of Wordpress don't like editing in widget areas, its too complex!!! Nor does the suggested solution provide the random selection of images.
Therefore, can I please ask for the same header image function in Themler theme to that of the Wordpress standard themes? It may need to be activated in Themler for it to be active in the end theme.
In the standard Wordpress Twenty Sixteen (and earlier themes) have an option to add a number of header images from within the Wordrpess CMS in the theme options. This is really easy for a CMS end user to do, as it includes a crop feature. Images can be randomised so that on page loads one of the images is randomly selected. There are answers to similar questions in this forum, with suggestions to use a widget and place an image there. end users of Wordpress don't like editing in widget areas, its too complex!!! Nor does the suggested solution provide the random selection of images. Therefore, can I please ask for the same header image function in Themler theme to that of the Wordpress standard themes? It may need to be activated in Themler for it to be active in the end theme.
Support Team posted this 27 September 2016
Thanks for the suggestion. I'll add it to our wish list for possible future implementations.
Hi, Thanks for the suggestion. I'll add it to our wish list for possible future implementations. Sincerely, Hella
len
len posted this 05 March 2017
Any progress with this please?
LenW
Hella Any progress with this please? Thanks LenW
Support Team posted this 06 March 2017
This option is not in our roadmap for now.
Hi, This option is not in our roadmap for now. Sincerely, Hella
len
len posted this 06 March 2017
Any reason why not? It an important addition that allows end users to change data in the CMS end, surely the point of a CMS system.
I thought Themler is about theme structure and design, not limiting data - and that includes images from the CMS backend.
Can you please ask that this be reconsidered.
LenW
Hella Any reason why not? It an important addition that allows end users to change data in the CMS end, surely the point of a CMS system. I thought Themler is about theme structure and design, not limiting data - and that includes images from the CMS backend. Can you please ask that this be reconsidered. Thanks LenW
The feature in the wish list, you can vote for it more to pay the developer's attention.
Also header image is a part of theme and not content that can be edited inside CMS. As a solution you can use the module position inside Header and insert the image there from the back end.
Hi, The feature in the wish list, you can vote for it more to pay the developer's attention. Also header image is a part of theme and not content that can be edited inside CMS. As a solution you can use the module position inside Header and insert the image there from the back end. Sincerely, Hella
