Show Custom Categories
Stagger Lee posted this 28 September 2016
Dont know for 100% if it is a bug, but you can check.
http://answers.themler.com/questions/63786/show-custom-categories-custom-post-type-taxonomy-terms-support
So it goes:
  • Activate Static Page for front
  • Check option to chose Custom Categories
  • Write some category slug
  • Deactiave all those options and delete slug
  • It shows only Homepage Page on front. And in some way WP_Query is confused and stuck on this Page. It should not show Pages at all, but Posts only.
I can test it on Cloud when you fix themes saving in our profiles.
  • Disabled all plugins and own code
  • Refreshed Permalinks several times
Did not help.
As soon I check option again and write category slug then it works nice.
Strange thing is when front shows wrong Themler edit screen shows it right. I deleted Appcache and hard reseted window too.
Dont know for 100% if it is a bug, but you can check. http://answers.themler.com/questions/63786/show-custom-categories-custom-post-type-taxonomy-terms-support So it goes: - Activate Static Page for front - Check option to chose Custom Categories - Write some category slug - Deactiave all those options and delete slug - It shows only Homepage **Page** on front. And in some way WP_Query is confused and stuck on this Page. It should not show Pages at all, but Posts only. I can test it on Cloud when you fix themes saving in our profiles. - Disabled all plugins and own code - Refreshed Permalinks several times Did not help. As soon I check option again and write category slug then it works nice. Strange thing is when front shows wrong Themler edit screen shows it right. I deleted Appcache and hard reseted window too.
Is Solution
You can disregard this one, except problem with themes in Profile here at themler.com.
It is normal behavior, when no category or Posts of course it has to show Homepage Page.
What drove me long in wrong direction is thas this page is via custom template done in an way with thumbnail and some meta data so it appeared as one simple Post. ( I have default featured image, so all Pages have it too by automatic.)
Solved & Closed.
You can disregard this one, except problem with themes in Profile here at themler.com. It is normal behavior, when no category or Posts of course it has to show Homepage **Page**. What drove me long in wrong direction is thas this page is via custom template done in an way with thumbnail and some meta data so it appeared as one simple Post. ( I have default featured image, so all Pages have it too by automatic.) Solved & Closed.
