Product slider issue in WooCommerce
PK Webdesign
PK Webdesign posted this 29 September 2016
Hi!
I´m using the product slider on the front page with the widget "WooCommerce Recent Products". I want to show 24 new products, and it only shows 15. Is there some restriction in themler, that restricts to 15 products?
/Peter
Hi! I´m using the product slider on the front page with the widget "WooCommerce Recent Products". I want to show 24 new products, and it only shows 15. Is there some restriction in themler, that restricts to 15 products? !product-slider.jpg! !widget-recent-products.jpg! /Peter
8 Comments
Support Team posted this 30 September 2016
Indeed, there is a limitation for number of items in product sliders.
You may try to change it manually:
1. Open \includes\products_slider_widgets_1.php file.
2. Find all the places where the code $number > 15 is mentioned.
3. Increase the value. This value would be the upper limit of product number in product slider, for example, to make it 16:
else if ( $number > 16 )
            $number = 16;
and change it in all other places $number > 15 is mentioned.
Hello, Indeed, there is a limitation for number of items in product sliders. You may try to change it manually: 1. Open `\includes\products_slider_widgets_1.php` file. 2. Find all the places where the code `$number > 15` is mentioned. 3. Increase the value. This value would be the upper limit of product number in product slider, for example, to make it 16: else if ( $number > 16 ) $number = 16; and change it in all other places `$number > 15` is mentioned. Sincerely, Nettie, BillionDigital Team
PK Webdesign
PK Webdesign posted this 03 October 2016
Thank you, it works fine now. Why doesn´t this function exist in Themler? It would be great to control this thing in there, instead of changing it manually.
/Peter
Hello, Thank you, it works fine now. Why doesn´t this function exist in Themler? It would be great to control this thing in there, instead of changing it manually. /Peter
Support Team posted this 03 October 2016
Hi Peter,
Thanks for the suggestion, we will add it to our Wishlist. Please feel free to contact us in any other case.
Hi Peter, Thanks for the suggestion, we will add it to our Wishlist. Please feel free to contact us in any other case. Sincerely, Nettie, BillionDigital Team
Rune
Rune posted this 08 December 2016
Can you please remove the limitation?
Support Team posted this 08 December 2016
Currently it is not possible but the suggestion is forwarded to developers, possibly there is some way to control this in the future. You may try using the suggestion from the post above, it should help.
Sincerel,y
Hello, Currently it is not possible but the suggestion is forwarded to developers, possibly there is some way to control this in the future. You may try using the suggestion from the post above, it should help. Sincerel,y Nettie, BillionDigital Team
Rune
Rune posted this 19 December 2016
What if.. You increase to 5000 in all files, then we can set your limit by ourselves in the widget
I have asked developers about such possibility and will keep you posted.
Hello, I have asked developers about such possibility and will keep you posted. Sincerely, Nettie, BillionDigital Team
Our developers have reported that the limit cannot be removed completely, because this may overload the database in case there are too many products. However they will consider the possibility to add an option or use another way, so that this value can be changed more quickly.
Hi, Our developers have reported that the limit cannot be removed completely, because this may overload the database in case there are too many products. However they will consider the possibility to add an option or use another way, so that this value can be changed more quickly. Sincerely, Nettie, BillionDigital Team
