I need to verify you are not going to repeat the HUGE oversite with Artisteer and SEO structure on templates, Joomla in particular.
As of now Artisteer outputs a SEO disaster that is not even fixable by editing the template after export.
Artisteer = Headline is H1 totally wrong, never have the same H1 tag on all pages and this destroys the opportunity to have a different one since you are NOT supposed to have multiple H1 tags on any page. Can be fixed manually after ever export. Huge pain in the...
Page Heading and Article Title are both H2 and cannot be changed even after export because they are the same class. In Joomla each page can have a Page Heading at the menu level customized for the page outside the page title tag. This is built into Joomla to have full control over SEO and is brilliant. Artisteer is killing this amazing opportunity. This should be an H1 tag and the Article Headings should remain the H2.
Are these going to be working in Themler? God I hope so. This cannot possibly be overlooked again.
I need to verify you are not going to repeat the HUGE oversite with Artisteer and SEO structure on templates, Joomla in particular. As of now Artisteer outputs a SEO disaster that is not even fixable by editing the template after export. 1. Artisteer = Headline is H1 totally wrong, never have the same H1 tag on all pages and this destroys the opportunity to have a different one since you are NOT supposed to have multiple H1 tags on any page. Can be fixed manually after ever export. Huge pain in the... 2. Page Heading and Article Title are both H2 and cannot be changed even after export because they are the same class. In Joomla each page can have a Page Heading at the menu level customized for the page outside the page title tag. This is built into Joomla to have full control over SEO and is brilliant. Artisteer is killing this amazing opportunity. This should be an H1 tag and the Article Headings should remain the H2. Are these going to be working in Themler? God I hope so. This cannot possibly be overlooked again.
