My menu has a problem
admin34
admin34 posted this 07 October 2016
When I go to my home page https://www.voguewebservices.com/ for some reason the menu thinks i'm on this page https://voguewebservices.secureapi.com.au/ which is called DOMAIN NAMES on my menu bar I have DOMAIN NAMES menu tab set as a custom link though menus in Wordpress. I know this because when i'm on the homepage there is no blue background. when I click on the home tab the DOMAIN NAMES tab lights up.
Allan
Hi When I go to my home page https://www.voguewebservices.com/ for some reason the menu thinks i'm on this page https://voguewebservices.secureapi.com.au/ which is called DOMAIN NAMES on my menu bar I have DOMAIN NAMES menu tab set as a custom link though menus in Wordpress. I know this because when i'm on the homepage there is no blue background. when I click on the home tab the DOMAIN NAMES tab lights up. Thanks Allan
Support Team posted this 10 October 2016
This issue should be fixed in the next Themler update. In the meantime please try creating Home menu item in the following way:
This may help.
Hi, This issue should be fixed in the next Themler update. In the meantime please try creating Home menu item in the following way: !home-item-2.png! This may help. Please let us know the result. Thank you, Olivia
admin34
admin34 posted this 10 October 2016
Hi Olivia,
Thanks for the idea, unfortunately it didn't work.
Hi Olivia, Thanks for the idea, unfortunately it didn't work.
Support Team posted this 11 October 2016
Please consider waiting for the next update that will solve this issue permanently.
Hi, Please consider waiting for the next update that will solve this issue permanently. Sincerely, Hella
admin34
admin34 posted this 12 October 2016
OK no problem :)
OK no problem :)
Support Team posted this 12 October 2016
Thanks for your patience.
Thanks for your patience. Sincerely, Hella
