error import template
Amilcar Botelho Rubim Junior
Amilcar Botelho Rubim Junior posted this 10 October 2016
When I export the Themler, included content, and care in Joomla appears the header, footer and content, is all right.
How do I import the same template in Themler, and in March the option of adding content, appears only header and footer.
How to solve this?
Att.
Amilcar
When I export the Themler, included content, and care in Joomla appears the header, footer and content, is all right. How do I import the same template in Themler, and in March the option of adding content, appears only header and footer. How to solve this? Att. Amilcar
Support Team posted this 11 October 2016
Sorry, your question is not clear. You import the theme that includes content in Themler? There should appear the message to replace content, choose that option, then content should be imported into the site you are working on.
Hi, Sorry, your question is not clear. You import the theme that includes content in Themler? There should appear the message to replace content, choose that option, then content should be imported into the site you are working on. Sincerely, Hella
Amilcar Botelho Rubim Junior posted this 11 October 2016
I will try to explain in more detail.
I'm working on 2 or 3 different templates, then export the template and install the Joommla, ok everything worked, including the content is imported.
Now I started another template and then create some items in this template I export to save.
Now I will return the previous template and will import it in Themler, when importing select the option to add content, BUT this content is not imported, remembering that did the installation in Joomla and conteúlo was correct.
Att..
Amilcar
I will try to explain in more detail. I'm working on 2 or 3 different templates, then export the template and install the Joommla, ok everything worked, including the content is imported. Now I started another template and then create some items in this template I export to save. Now I will return the previous template and will import it in Themler, when importing select the option to add content, BUT this content is not imported, remembering that did the installation in Joomla and conteúlo was correct. Att.. Amilcar
Support Team posted this 13 October 2016
Hello Amilcar,
please attach here the ZIP file with theme which content is not added when you import it into Themler.
Hello Amilcar, please attach here the ZIP file with theme which content is not added when you import it into Themler. Regards, Aileen
