Change Sidebar
engels
engels posted this 11 October 2016
I would like to change the size, hover features and more of my sidebar, however i am not able to find the option to change said features. I'm workig with WordPress if that makes any difference.
Support Team posted this 11 October 2016
Please explain in more details what you want to change in the sidebar? In the whole sidebar or in the widget area? Some screen shots will be helpful.
Hi, Please explain in more details what you want to change in the sidebar? In the whole sidebar or in the widget area? Some screen shots will be helpful. Sincerely, Hella
engels
Ok so basically I need to change the drop down arrows as well as just everything written in there... for example I would like to delete the third entry "Fujirock".
https://postimg.org/image/r5jxsr8mr/5e522443/
Ok so basically I need to change the drop down arrows as well as just everything written in there... for example I would like to delete the third entry "Fujirock". https://postimg.org/image/r5jxsr8mr/5e522443/
The arrows are the bullets of the bullet list. It can be changed under the Design >> Bullet list >> Icon.
The text is the name of the menu items, that should be changed under the CMS admin panel in the corresponding module.
Hi, The arrows are the bullets of the bullet list. It can be changed under the Design >> Bullet list >> Icon. The text is the name of the menu items, that should be changed under the CMS admin panel in the corresponding module. Sincerely, Hella
engels
We managed to find out what the problem was. We created a new menu as you can see in the image. The only thing that we would like to change is the 2 sub-categories on the right need to be placed below the actual catergory. (in this case "Superhartgipse" and "fujirock" should show up below "modellherstellung". Themler only gives us the option to show it on the right or left side.
https://postimg.org/image/qp7bfpu1v/
We managed to find out what the problem was. We created a new menu as you can see in the image. The only thing that we would like to change is the 2 sub-categories on the right need to be placed below the actual catergory. (in this case "Superhartgipse" and "fujirock" should show up below "modellherstellung". Themler only gives us the option to show it on the right or left side. https://postimg.org/image/qp7bfpu1v/
Unfortunately there is no such possibility.
Unfortunately there is no such possibility. Sincerely, Hella
