I can't see System Fonts list, only web fonts and Google web fonts.
Please help me.
Please help me.
What do you want with System-Fonts, which you cant use on a website!?
What do you want with System-Fonts, which you cant use on a website!?I want to use system font but I can't see the list when I choose "System Font" from the Font Option menu.
I want to use system font but I can't see the list when I choose "System Font" from the Font Option menu.WHY?!
If another website visitor doesnt have the font installed he cant see the font and will se times new roman!
DONT USE SYSTEM FONTS!
Hi Paolo,
Please make sure that Flash in browser is not blocked on your side.
This may cause System Fonts to be hidden.
Ivan
Thankyou so much, Ivan.
It works!!!
Good evening.
Flash on Google Chrome is enabled but I can not see the same fonts system.
You only see a gray line. (See attached image)
What can I do?
Hello Paolo,
do you mean that the option 'I font di sistema' does not open ? Or scroll does not work?
Please try to open Themler from differemt browser, e.g. FireFox and check this option. Does it work?
I had to open Themler in a normal window in Chrome - I was trying in Incognito mode.
Then in the address bar, manage blocking plugins > allow 127.0.0.1
Refresh the page and it should work now.
I had to open Themler in a normal window in Chrome - I was trying in Incognito mode. Then in the address bar, manage blocking plugins > allow 127.0.0.1 Refresh the page and it should work now.
