Hover box make hyperlink like read more for posts
ancimer.anze
ancimer.anze posted this 11 October 2016
Hello! Do you know if it is possible to make over slide of hover box clickable with hyperlink to posts? Just like hyperlink of Post Read More do?
11 Comments
Support Team posted this 12 October 2016
Simply insert the button with the link to your concrete post page. Make sure that you use the correct link to the post from the live site.
Hi, Simply insert the button with the link to your concrete post page. Make sure that you use the correct link to the post from the live site. Sincerely, Hella
robert.strohmaier
robert.strohmaier posted this 04 December 2016
I have a similar question regarding the hover box.
I'm using hover box for my blog template. And I'd like to use the whole over slide as a button to go to the post. It should react the same way like the default behavior of the "Post Header" component. When I click here, it leads me directly to the connected post.
Is it possible to configure the over slide of the hover box to do the same thing like the post header link? I don't want to add the specific links manually. Wouldn't make sense anyway for a CMS.
Thank you very much for your help in advance!
Kind regards,
Robert
Hello, I have a similar question regarding the hover box. I'm using hover box for my blog template. And I'd like to use the whole over slide as a button to go to the post. It should react the same way like the default behavior of the "Post Header" component. When I click here, it leads me directly to the connected post. Is it possible to configure the over slide of the hover box to do the same thing like the post header link? I don't want to add the specific links manually. Wouldn't make sense anyway for a CMS. Thank you very much for your help in advance! Kind regards, Robert
Support Team posted this 06 December 2016
Hi Robert,
Hover Box is a simple html control. This is container for other controls and it has no connection to CMS. Therefore there is no easy way to achieve this except adding Post image to the hover slide. Post Image is an image link to the article.
To navigate the CMS article you need to place something to the hover slide which will navigate to the article. In other words you need a link to the article.
As a possible solution you can place CMS Code control (Insert tab >> More) on the hover slide and add the following code:
<?php if (isset($data['header-text']) && strlen($data['header-text'])) : ?>
<?php if (isset($data['header-link']) && strlen($data['header-link'])) : ?>
<a <?php echo funcBuildRoute($data['header-link'], 'href'); ?>>
<?php echo $data['header-text'];?>
</a>
<?php else: ?>
<?php echo $data['header-text']; ?>
<?php endif; ?>
<?php endif; ?>
This code creates a link to the article.
Bu removing <?php echo $data['header-text'];?> line you can create empty link.
This empty link can be stretched to the whole size of the CMS Code control:
< a style="display: block; width: 100%; height: 100%" <?php echo funcBuiltRoute...
The control itself should be stretched the the whole size of the hover slide.
Hi Robert, Hover Box is a simple html control. This is container for other controls and it has no connection to CMS. Therefore there is no easy way to achieve this except adding Post image to the hover slide. Post Image is an image link to the article. To navigate the CMS article you need to place something to the hover slide which will navigate to the article. In other words you need a link to the article. As a possible solution you can place CMS Code control (Insert tab >> More) on the hover slide and add the following code: ` <?php if (isset($data['header-text']) && strlen($data['header-text'])) : ?> <?php if (isset($data['header-link']) && strlen($data['header-link'])) : ?> <a <?php echo funcBuildRoute($data['header-link'], 'href'); ?>> <?php echo $data['header-text'];?> </a> <?php else: ?> <?php echo $data['header-text']; ?> <?php endif; ?> <?php endif; ?>` This code creates a link to the article. Bu removing `<?php echo $data['header-text'];?>` line you can create empty link. This empty link can be stretched to the whole size of the CMS Code control: `< a style="display: block; width: 100%; height: 100%" <?php echo funcBuiltRoute...` The control itself should be stretched the the whole size of the hover slide. Thank you, Olivia
robert.strohmaier
robert.strohmaier posted this 08 January 2017
Hi Olivia,
thank you very much! I tried to use and edit the script, but it doesn't work for my purposes.
In general it works. But now the hover effect from the hover box is no longer working. When I move the mouse over the Post image, I can click it, but no hovering effect at all.
Could you please tell me, what commands I have to add to the script to bring back the hover effect?
Thanks a lot,
Robert
Hi Olivia, thank you very much! I tried to use and edit the script, but it doesn't work for my purposes. In general it works. But now the hover effect from the hover box is no longer working. When I move the mouse over the Post image, I can click it, but no hovering effect at all. Could you please tell me, what commands I have to add to the script to bring back the hover effect? Thanks a lot, Robert
Support Team posted this 11 January 2017
The solution works just fine on my side. I've added a CMS Code control to the hover slide.
Could you please attach the theme with provided solution so we can check it on our side? If you do not want to attach it here please create new Private topic.
Hi, The solution works just fine on my side. I've added a CMS Code control to the hover slide. Could you please attach the theme with provided solution so we can check it on our side? If you do not want to attach it here please create new Private topic. Thank you, Olivia
robert.strohmaier
robert.strohmaier posted this 12 January 2017
Hi Olivia,
I've done the steps you've mentioned again and now it ist working. Thank you very much for your code!
Unfortunately I have another question regarding the hover box: If the mouse cursor is above the box with the Post Header the Over Slide appears. Do you have an idea, how to implement the same functionality to the Post Image? It would be great if the Over Slide also appears, if I move the mouse cursor over the Post Image. I think I've had this functionality already, but now it is gone.
All the best,
Robert
Hi Olivia, I've done the steps you've mentioned again and now it ist working. Thank you very much for your code! Unfortunately I have another question regarding the hover box: If the mouse cursor is above the box with the Post Header the Over Slide appears. Do you have an idea, how to implement the same functionality to the Post Image? It would be great if the Over Slide also appears, if I move the mouse cursor over the Post Image. I think I've had this functionality already, but now it is gone. All the best, Robert
Support Team posted this 17 January 2017
Hello Robert,
you may add the HoverBox control inside the Posts control. Locate the Post header control on the Back Slide of the Hover Box and locate the Post Image control on the Over Slide.
Hello Robert, you may add the HoverBox control inside the Posts control. Locate the Post header control on the Back Slide of the Hover Box and locate the Post Image control on the Over Slide. Regards, Aileen
robert.strohmaier
robert.strohmaier posted this 17 January 2017
Hello Aileen,
your solution sounds very logic. But I have no idea how to do that in Themler.
Could you please be so kind and post screenshots to show how to perform the steps in your answer.
Thank you very much in advance!
All the best,
Robert
Hello Aileen, your solution sounds very logic. But I have no idea how to do that in Themler. Could you please be so kind and post screenshots to show how to perform the steps in your answer. Thank you very much in advance! All the best, Robert
Support Team posted this 19 January 2017
Hello Robert,
you may apply one of predefined layouts to Blog for testing and check the settings of Hover Box
Hello Robert, you may apply one of predefined layouts to Blog for testing and check the settings of Hover Box !HBox.png! Regards, Aileen
tekgearco098
tekgearco098 posted this 21 April 2026
https://myanimelist.net/profile/tekgearco
https://devfolio.co/@tekgearco/readme-md
https://weboworld.com/listing/england/washington/Shopping-2/tek-gear-clothing-2
https://www.pubpub.org/user/smith-jackson
https://groups.google.com/g/tek-gear-clothing-brand
https://all4.vip/p/page/view-persons-profile?id=115554
https://linktr.ee/tekgearco
https://www.malaysialistings.com/listings/tek-gear-brand
https://www.daddycow.com/topics/view/9407
https://unbusinessnews.com/2026/03/03/upgrade-your-wardrobe-with-tek-gear-athletic-essentials-line-2026/
https://metaldevastationradio.com/tekgearcos
https://co-roma.openheritage.eu/profiles/_1363/activity
https://log.concept2.com/profile/2873188
https://openlibrary.org/people/tekk_gear
https://community.windy.com/user/tekk-gear
https://qiita.com/tekgearco098
https://issuu.com/tekgearco
https://steemit.com/tekgear/@fainamiller/stay-comfortable-and-active-with-tek-gear-performance-wear
https://huggingface.co/tekgearco098
https://www.walkscore.com/people/166326220219/walk-score-user
https://www.magcloud.com/user/tekgearr2
https://glass-sock-ae9.notion.site/Move-Freely-with-Comfortable-Tek-Gear-Activewear-Styles-3253535ab01c8080a372f2aff01a3c47?pvs=73
https://slides.com/d/GfLID2A/speaker/qbk9EpU
https://tekgearco.start.page/
https://leetcode.com/u/tekgearco098/
https://gitlab.com/tekgearco098
https://www.designspiration.com/tekgearco098/saves/
https://tekgearco.exposure.co/
https://community.intercom.com/apps-integrations-25/mcp-for-europe-14035?postid=37347#post37347
https://tekgearco.mypixieset.com/
https://www.instapaper.com/p/17551987
https://savee.com/tekgearco098/
https://webyourself.eu/blogs/1847034/Comfortable-Tek-Gear-Activewear-for-Everyday-Performance
https://www.proko.com/@tekk_gear/activity
https://experiment.com/users/jjackyjames
https://review.stylevore.com/tek-gear-brand/
https://review.gymbuddynow.com/tek-gear-brand/
https://fueler.io/tekgearco09
https://gitlab.aicrowd.com/tekk_gear
https://stocktwits.com/tekgearco
https://community.shopify.com/t/improving-navigation-in-my-shopify-store/592283/5
https://tekgear2.gumroad.com/?_gl=19cpznh_ga*NDAxNDYzODExLjE3NzM3NzQ1NzU.*_ga_6LJN6D94N6*czE3NzM3NzQ1NzQkbzEkZzEkdDE3NzM3NzQ2NjQkajQzJGwwJGgw
https://www.intensedebate.com/people/tekg2
https://doodleordie.com/profile/tekgearco
https://www.getlisteduae.com/listings/tek-gear-clothing-bran
https://land-book.com/tekk_gear_374132
https://pinshape.com/users/8929728-tekgearco09?tab=designs
https://www.freelistingaustralia.com/listings/tek-gear-brand
https://www.wantoask.com/user/tekgear
https://eilo.org/user/tekgearco
https://hypothes.is/users/tekgearco
https://www.yumpu.com/user/tekk.gear
https://comunitat.canodrom.barcelona/profiles/tekk_gear/activity?locale=en
https://www.freelistingusa.com/listings/tek-gear-brand
https://www.myfishingreport.com/blog-view.php?id=39328
https://www.whizolosophy.com/category/choices-decisions/article-essay/stay-comfortable-and-stylish-with-tek-gear-activewear-gear
https://workforgood.co.uk/businesses/tek-gear-brand
https://open.spotify.com/episode/2SFY4B6coha5wAndiqRLPk?si=QxVLvpiURZKuMqhap8cHqg
https://listen.hubhopper.com/episode/tek-gear-clothing-2026-podcast/32991150
https://dreevoo.com/profile.php?pid=1339184
https://soundcloud.com/tekk-gear/tek-gear-co-podcast
https://www.mixcloud.com/tekgearco/tek-gear-clothing-podcast-2026/
https://open.firstory.me/story/cmmwhh3vo01cw01zkh7b5gbsu
https://myanimelist.net/profile/tekgearco https://devfolio.co/@tekgearco/readme-md https://weboworld.com/listing/england/washington/Shopping-2/tek-gear-clothing-2 https://www.pubpub.org/user/smith-jackson https://groups.google.com/g/tek-gear-clothing-brand https://all4.vip/p/page/view-persons-profile?id=115554 https://linktr.ee/tekgearco https://www.malaysialistings.com/listings/tek-gear-brand https://www.daddycow.com/topics/view/9407 https://unbusinessnews.com/2026/03/03/upgrade-your-wardrobe-with-tek-gear-athletic-essentials-line-2026/ https://metaldevastationradio.com/tekgearcos https://co-roma.openheritage.eu/profiles/_1363/activity https://log.concept2.com/profile/2873188 https://openlibrary.org/people/tekk_gear https://community.windy.com/user/tekk-gear https://qiita.com/tekgearco098 https://issuu.com/tekgearco https://steemit.com/tekgear/@fainamiller/stay-comfortable-and-active-with-tek-gear-performance-wear https://huggingface.co/tekgearco098 https://www.walkscore.com/people/166326220219/walk-score-user https://www.magcloud.com/user/tekgearr2 https://glass-sock-ae9.notion.site/Move-Freely-with-Comfortable-Tek-Gear-Activewear-Styles-3253535ab01c8080a372f2aff01a3c47?pvs=73 https://slides.com/d/GfLID2A/speaker/qbk9EpU https://tekgearco.start.page/ https://leetcode.com/u/tekgearco098/ https://gitlab.com/tekgearco098 https://www.designspiration.com/tekgearco098/saves/ https://tekgearco.exposure.co/ https://community.intercom.com/apps-integrations-25/mcp-for-europe-14035?postid=37347#post37347 https://tekgearco.mypixieset.com/ https://www.instapaper.com/p/17551987 https://savee.com/tekgearco098/ https://webyourself.eu/blogs/1847034/Comfortable-Tek-Gear-Activewear-for-Everyday-Performance https://www.proko.com/@tekk_gear/activity https://experiment.com/users/jjackyjames https://review.stylevore.com/tek-gear-brand/ https://review.gymbuddynow.com/tek-gear-brand/ https://fueler.io/tekgearco09 https://gitlab.aicrowd.com/tekk_gear https://stocktwits.com/tekgearco https://community.shopify.com/t/improving-navigation-in-my-shopify-store/592283/5 https://tekgear2.gumroad.com/?_gl=1*9cpznh*_ga*NDAxNDYzODExLjE3NzM3NzQ1NzU.*_ga_6LJN6D94N6*czE3NzM3NzQ1NzQkbzEkZzEkdDE3NzM3NzQ2NjQkajQzJGwwJGgw https://www.intensedebate.com/people/tekg2 https://doodleordie.com/profile/tekgearco https://www.getlisteduae.com/listings/tek-gear-clothing-bran https://land-book.com/tekk_gear_374132 https://pinshape.com/users/8929728-tekgearco09?tab=designs https://www.freelistingaustralia.com/listings/tek-gear-brand https://www.wantoask.com/user/tekgear https://eilo.org/user/tekgearco https://hypothes.is/users/tekgearco https://www.yumpu.com/user/tekk.gear https://comunitat.canodrom.barcelona/profiles/tekk_gear/activity?locale=en https://www.freelistingusa.com/listings/tek-gear-brand https://www.myfishingreport.com/blog-view.php?id=39328 https://www.whizolosophy.com/category/choices-decisions/article-essay/stay-comfortable-and-stylish-with-tek-gear-activewear-gear https://workforgood.co.uk/businesses/tek-gear-brand https://open.spotify.com/episode/2SFY4B6coha5wAndiqRLPk?si=QxVLvpiURZKuMqhap8cHqg https://listen.hubhopper.com/episode/tek-gear-clothing-2026-podcast/32991150 https://dreevoo.com/profile.php?pid=1339184 https://soundcloud.com/tekk-gear/tek-gear-co-podcast https://www.mixcloud.com/tekgearco/tek-gear-clothing-podcast-2026/ https://open.firstory.me/story/cmmwhh3vo01cw01zkh7b5gbsu
tekgearco098
https://referrallist.com/profile/smith-wilson/
https://sabaylok.com/blogs/69815/Tek-Gear-Activewear-for-Everyday-Comfort-and-Performance
https://ulystar.in/blogs/94901/Upgrade-Your-Fitness-Style-with-Tek-Gear-Activewear
https://www.cake.me/me/tekk-gear
https://www.ganjingworld.com/news/1idp70t871772gElu1fb34z0i16j1c/move-better-with-stylish-tek-gear-activewear-essentials
http://www.golocalezservices.com/shipping-delivery/tek-gear
https://www.provenexpert.com/smith28/?mode=preview
https://www.qurito.io/question/1751469263425/logo-clothing-wearable-branding-that-speaks-volumes/
https://www.rumorcircle.com/blogs/255296/Stay-Active-and-Comfortable-with-Tek-Gear-Activewear
https://www.scenario.press/blogs/323341/Experience-Comfort-and-Performance-with-Tek-Gear-Activewear
https://www.usafreeclassifieds.org/classifieds/business-opportunities_2/general/tek-gear-clothing_i971410
https://eo-college.org/members/tekgearco/
https://castbox.fm/channel/Women%E2%80%99s-Clothing-Store-in-Barbados-id5474041?country=us
https://expressy.co.in/experience-ultimate-performance-with-tek-gear-activewear-essentials/
https://inkbunny.net/tekgearco
https://plazoo.in.net/article/move-with-ease-in-tek-gear-active-pants-for-every-activity
https://projectcasting.com/professional/jacks-william
https://www.workingholidayjobs.com.au/forums/users/tekg12/
http://jobs.emiogp.com/author/tekgo1/
https://animead.com/user/profile/51728
https://blogswirl.in.net/article/tek-gear-pants-built-for-flexibility-and-everyday-wear
https://edostate.com/thread/62560
https://freeglobalclassifiedads.com/business-opportunities_2/general/tek-gear-clothing_i3260651
https://www.articledude.com/classifieds/for-sale/tek-gear-clothing_i151967
https://www.leadclub.net/classifieds/for-sale/tek-gear-clothing_i105234
https://www.mysportsgo.com/profile/131729
https://bizidex.com/en/tek-gear-brand-fashion-shop-908105
https://www.chimty.com/listing/washington/airway-heights-147/Other-2/tek-gear-brand
https://www.gooalsocial.com/topics/view/650
https://kisanlink.com/forums/discussion/general-discussion/red-hood-jackets
https://tutorialslink.com/member/Tekkgear/95152
https://www.aviacionargentina.net/user/tekgearco
https://my.lawschoolnumbers.com/tekkgear
https://www.reviewadda.com/asks/how-do-i-express-my-personality-through-streetwear-styles-by-combining-different-brands-and-clothing-items
https://www.soshified.com/forums/user/664507-tekgearco/
https://triberr.com/tekgearco
https://www.divephotoguide.com/user/tekgear1
https://www.freelistingindia.in/listings/tek-gear-clothing-brand
https://www.hopp.bio/tekk-gear
https://zumvu.com/tekgearco/
https://joinentre.com/profile/tekgearco
https://app.wedonthavetime.org/profile/tekk_gear
https://justpaste.me/8Ddw7
https://participacion.puertodelrosario.org/profiles/tekkgear1/activity
https://dapp.orvium.io/profile/tekk-gear
https://forum.liquidbounce.net/user/tekgearco09
https://tekgearclothing.mobirisesite.com/
https://findaspring.org/members/tekkgear/profile/
https://www.campfirewriting.com/user/tekgearc
https://www.checkli.com/tekgearco
https://pastelink.net/u31igqgt
https://www.ewebdiscussion.com/threads/leadinglady-in-shop-lingerie-shapewear-activewear-online.287688/
https://hearthis.at/tekk-gear/tek-gear-co-podcast/oUW/
https://www.myminifactory.com/users/tekkgear
https://www.tkaraoke.com/forums/profile/tekgearco098gmail-com/
https://gravatar.com/kryptoniteunique5c6c1015af
https://www.techrepublic.com/forums/discussions/will-ai-replace-white-collar-workers-or-just-reshape-their-roles/#post-4354539
https://solo.to/tekgearco
https://worldvectorlogo.com/profile/tekk-gear
https://www.speedrun.com/users/tekgearco
https://www.spreaker.com/episode/tek-gear-co-podcast--71119090
https://my.usaflag.org/members/tekgear2/profile/
https://tapas.io/tekgearco098
https://leasedadspace.com/members/tekgearco2/
https://www.pinterest.com/tekgearco098/_profile/
https://www.hulkshare.com/tekgearco1
https://www.babelcube.com/user/mike-jackson
https://www.futurelearn.com/profiles/23121099
https://www.anime-planet.com/users/mikewilson2
https://unsplash.com/@tekgearco1
https://speakerdeck.com/tekgearco1
https://hub.docker.com/u/tekgearco1?_gl=1ioye42_gcl_au*MTUwMDcxMTc3Mi4xNzc1NzQyNTQz*_ga*MTMwNzkzMjE3NS4xNzc1NzQyNTQy*_ga_XJWPQMJYHQ*czE3NzU3NDI1NDEkbzEkZzEkdDE3NzU3NDI1OTckajQkbDAkaDA.
https://www.facer.io/u/Tekgearco
https://hosted.weblate.org/user/mikewilson2/
https://www.inkitt.com/tekgearbrand
https://mercadodinamico.com.br/author/tekgo1/
https://kuula.co/profile/kl54966
https://www.komoot.com/user/5654036467281
https://wakelet.com/wake/LkuNc7aaN7hJZem6L4ALd
https://www.tripadvisor.com/Profile/tekkg2026
https://peatix.com/user/29343281/view
https://decidim.santcugat.cat/profiles/tekk_gear/activity
https://open.firstory.me/story/cmmwhh3vo01cw01zkh7b5gbsu https://referrallist.com/profile/smith-wilson/ https://sabaylok.com/blogs/69815/Tek-Gear-Activewear-for-Everyday-Comfort-and-Performance https://ulystar.in/blogs/94901/Upgrade-Your-Fitness-Style-with-Tek-Gear-Activewear https://www.cake.me/me/tekk-gear https://www.ganjingworld.com/news/1idp70t871772gElu1fb34z0i16j1c/move-better-with-stylish-tek-gear-activewear-essentials http://www.golocalezservices.com/shipping-delivery/tek-gear https://www.provenexpert.com/smith28/?mode=preview https://www.qurito.io/question/1751469263425/logo-clothing-wearable-branding-that-speaks-volumes/ https://www.rumorcircle.com/blogs/255296/Stay-Active-and-Comfortable-with-Tek-Gear-Activewear https://www.scenario.press/blogs/323341/Experience-Comfort-and-Performance-with-Tek-Gear-Activewear https://www.usafreeclassifieds.org/classifieds/business-opportunities_2/general/tek-gear-clothing_i971410 https://eo-college.org/members/tekgearco/ https://castbox.fm/channel/Women%E2%80%99s-Clothing-Store-in-Barbados-id5474041?country=us https://expressy.co.in/experience-ultimate-performance-with-tek-gear-activewear-essentials/ https://inkbunny.net/tekgearco https://plazoo.in.net/article/move-with-ease-in-tek-gear-active-pants-for-every-activity https://projectcasting.com/professional/jacks-william https://www.workingholidayjobs.com.au/forums/users/tekg12/ http://jobs.emiogp.com/author/tekgo1/ https://animead.com/user/profile/51728 https://blogswirl.in.net/article/tek-gear-pants-built-for-flexibility-and-everyday-wear https://edostate.com/thread/62560 https://freeglobalclassifiedads.com/business-opportunities_2/general/tek-gear-clothing_i3260651 https://www.articledude.com/classifieds/for-sale/tek-gear-clothing_i151967 https://www.leadclub.net/classifieds/for-sale/tek-gear-clothing_i105234 https://www.mysportsgo.com/profile/131729 https://bizidex.com/en/tek-gear-brand-fashion-shop-908105 https://www.chimty.com/listing/washington/airway-heights-147/Other-2/tek-gear-brand https://www.gooalsocial.com/topics/view/650 https://kisanlink.com/forums/discussion/general-discussion/red-hood-jackets https://tutorialslink.com/member/Tekkgear/95152 https://www.aviacionargentina.net/user/tekgearco https://my.lawschoolnumbers.com/tekkgear https://www.reviewadda.com/asks/how-do-i-express-my-personality-through-streetwear-styles-by-combining-different-brands-and-clothing-items https://www.soshified.com/forums/user/664507-tekgearco/ https://triberr.com/tekgearco https://www.divephotoguide.com/user/tekgear1 https://www.freelistingindia.in/listings/tek-gear-clothing-brand https://www.hopp.bio/tekk-gear https://zumvu.com/tekgearco/ https://joinentre.com/profile/tekgearco https://app.wedonthavetime.org/profile/tekk_gear https://justpaste.me/8Ddw7 https://participacion.puertodelrosario.org/profiles/tekkgear1/activity https://dapp.orvium.io/profile/tekk-gear https://forum.liquidbounce.net/user/tekgearco09 https://tekgearclothing.mobirisesite.com/ https://findaspring.org/members/tekkgear/profile/ https://www.campfirewriting.com/user/tekgearc https://www.checkli.com/tekgearco https://pastelink.net/u31igqgt https://www.ewebdiscussion.com/threads/leadinglady-in-shop-lingerie-shapewear-activewear-online.287688/ https://hearthis.at/tekk-gear/tek-gear-co-podcast/oUW/ https://www.myminifactory.com/users/tekkgear https://www.tkaraoke.com/forums/profile/tekgearco098gmail-com/ https://gravatar.com/kryptoniteunique5c6c1015af https://www.techrepublic.com/forums/discussions/will-ai-replace-white-collar-workers-or-just-reshape-their-roles/#post-4354539 https://solo.to/tekgearco https://worldvectorlogo.com/profile/tekk-gear https://www.speedrun.com/users/tekgearco https://www.spreaker.com/episode/tek-gear-co-podcast--71119090 https://my.usaflag.org/members/tekgear2/profile/ https://tapas.io/tekgearco098 https://leasedadspace.com/members/tekgearco2/ https://www.pinterest.com/tekgearco098/_profile/ https://www.hulkshare.com/tekgearco1 https://www.babelcube.com/user/mike-jackson https://www.futurelearn.com/profiles/23121099 https://www.anime-planet.com/users/mikewilson2 https://unsplash.com/@tekgearco1 https://speakerdeck.com/tekgearco1 https://hub.docker.com/u/tekgearco1?_gl=1*ioye42*_gcl_au*MTUwMDcxMTc3Mi4xNzc1NzQyNTQz*_ga*MTMwNzkzMjE3NS4xNzc1NzQyNTQy*_ga_XJWPQMJYHQ*czE3NzU3NDI1NDEkbzEkZzEkdDE3NzU3NDI1OTckajQkbDAkaDA. https://www.facer.io/u/Tekgearco https://hosted.weblate.org/user/mikewilson2/ https://www.inkitt.com/tekgearbrand https://mercadodinamico.com.br/author/tekgo1/ https://kuula.co/profile/kl54966 https://www.komoot.com/user/5654036467281 https://wakelet.com/wake/LkuNc7aaN7hJZem6L4ALd https://www.tripadvisor.com/Profile/tekkg2026 https://peatix.com/user/29343281/view https://decidim.santcugat.cat/profiles/tekk_gear/activity
