Add image on slider
webmaster@exnet.gr
webmaster@exnet.gr posted this 12 October 2016
i would like ot ask how can I add 2 more slides on template without using themler at all.
Thanks in advance!
Hello, i would like ot ask how can I add 2 more slides on template without using themler at all. Thanks in advance!
Support Team posted this 12 October 2016
That is not possible, the slider can be edited inside Themler only. In case you need to edit the slider without using the application, please consider using some external slider plug-in.
Hi, That is not possible, the slider can be edited inside Themler only. In case you need to edit the slider without using the application, please consider using some external slider plug-in. Sincerely, Hella
