Change text links only
rogier
rogier posted this 12 October 2016
Dear Madam or Sir,
On my website I would like to change the formatting of text links only (add underlining).
But when I change this in Themler, all types of links are affected: headers, lists, buttons and menu's alike.
In paragraph options you can change these settings back for each of these other types separately which takes a lot of additional work, but I guess that is not intended.
So how do I change text links only without the extra work of repairing unintended changes?
Kind regards,
Rogier van de Ree
Dear Madam or Sir, On my website I would like to change the formatting of text links only (add underlining). But when I change this in Themler, all types of links are affected: headers, lists, buttons and menu's alike. In paragraph options you can change these settings back for each of these other types separately which takes a lot of additional work, but I guess that is not intended. So how do I change text links only without the extra work of repairing unintended changes? Kind regards, Rogier van de Ree
17 Comments
Support Team posted this 13 October 2016
All these elements use text links (html <a> element).
Almost all controls have own text styles under the "More Styles" menu where you can configure typography for this control only:
Hi, > But when I change this in Themler, all types of links are affected: headers, lists, buttons and menu's alike. All these elements use text links (html `<a>` element). Almost all controls have own text styles under the "More Styles" menu where you can configure typography for this control only: !more-styles.png! Thank you, Olivia
rogier
rogier posted this 13 October 2016
Dear Olivia,
That is what I already wrote in my question.
So the answer is "No", there is no way to change text links only.
When I want that, I will have to reset this for every control and style element used, which is quite a bit of work...
Rogier
Dear Olivia, That is what I already wrote in my question. So the answer is "No", there is no way to change text links only. When I want that, I will have to reset this for every control and style element used, which is quite a bit of work... Regards, Rogier
Support Team posted this 17 October 2016
Hello Rogier,
in fact, you're right: the changes could be made at global level at Design tab or each control could be changed via More Styles.
let us know if you have additional questions
Hello Rogier, in fact, you're right: the changes could be made at global level at Design tab or each control could be changed via More Styles. let us know if you have additional questions regards, Aileen
rogier
rogier posted this 03 November 2016
Dear Aileen,
When I changed the color only, it worked only on the text links. List links in the sidebar were not affected. So I kinda found something to make it work acceptably.
Regards, Rogier
Dear Aileen, When I changed the color only, it worked only on the text links. List links in the sidebar were not affected. So I kinda found something to make it work acceptably. Regards, Rogier
Support Team posted this 03 November 2016
You are welcome. Let us know if you need our further help.
You are welcome. Let us know if you need our further help. Sincerely, Hella
JakeBakerClam
JakeBakerClam posted this 26 November 2016
Currently, if you want links in paragraph text to be underlined (not all other links in headings, lists, etc.), you have to add the following custom css in the "Additional CSS" box found on the "Home" tab in "Settings":
p a:link {
text-decoration: underline;
Currently, if you want links in paragraph text to be underlined (not all other links in headings, lists, etc.), you have to add the following custom css in the "Additional CSS" box found on the "Home" tab in "Settings": p a:link { text-decoration: underline; }
Stagger Lee posted this 26 November 2016
Why are you doing this. All links are posible to style locally, not globally. Olivia is missinforming somehow.
If you by chance hit some strange situation where it is not possible put that block in empty Section and all styling for text and links are done via Section settings.
Why are you doing this. All links are posible to style locally, not globally. Olivia is missinforming somehow. If you by chance hit some strange situation where it is not possible put that block in empty Section and all styling for text and links are done via Section settings.
rogier
rogier posted this 28 November 2016
Dear Jake and Stagger,
Thanks for your tips.
Why? To increase readability throughout my website I wanted the links in my text to be more recognizable. That is: only in text, not in headers, lists, etc. When I set the appropriate element in "Design" (as this should be a global change) to use underline, all other elements using links are affected too. When I change only the text link color it is works fine.
As you might expect I consider this unexpected behaviour of Themler. Or in short: this is a bug.
Using custom CSS is not a solution, it is a work around. Moreover, when something is repaired or changed in a next version, it is actively blocking this improvement.
Looking forward to your opinion.
Regards, Rogier
Dear Jake and Stagger, Thanks for your tips. Why? To increase readability throughout my website I wanted the links in my text to be more recognizable. That is: only in text, not in headers, lists, etc. When I set the appropriate element in "Design" (as this should be a global change) to use underline, all other elements using links are affected too. When I change only the text link color it is works fine. As you might expect I consider this unexpected behaviour of Themler. Or in short: this is a bug. Using custom CSS is not a solution, it is a work around. Moreover, when something is repaired or changed in a next version, it is actively blocking this improvement. Looking forward to your opinion. Regards, Rogier
Stagger Lee posted this 28 November 2016
What is it for inserted control ? Or it is content control only ?
rogier
Dear Stagger,
I am not sure what you mean by "inserted control". It is about static text on my pages and blogs.
Regards, Rogier
Dear Stagger, I am not sure what you mean by "inserted control". It is about static text on my pages and blogs. Regards, Rogier
It is impossible that you are saying. Changing content links never change Menu links, or in Sidebars. I have never had problem localizing links style in template and content.
Anyway you have to click on "Customize this template" twice to make it independent from rest of website. One is under Settings tab - Background option. Second is when you click on Post header, Posts options.
And "text link" is wrong naming. If it is WordPress in this world it means links as text, WITHOUT "a" tags.
But OK, seems as you meant real links, not text only,
It is impossible that you are saying. Changing content links never change Menu links, or in Sidebars. I have never had problem localizing links style in template and content. Anyway you have to click on "Customize this template" twice to make it independent from rest of website. One is under Settings tab - Background option. Second is when you click on Post header, Posts options. And "text link" is wrong naming. If it is WordPress in this world it means links as text, WITHOUT "a" tags. But OK, seems as you meant real links, not text only,
JakeBakerClam
JakeBakerClam posted this 28 November 2016
I experienced the same problem as @Rogier
I wanted links in body text to be underlined. When I went to Design/More Styles/Text to set Links to be underlined, Themler applied the underline attribute GLOBALLY to ALL links. So links in all the Headings, Lists, Button, etc. got underlines, which is not what I want.
The attached image shows the Text flyout, with underline selected for Links. As you can see, the underline attribute is applied Globally.
My workaround was to put
p a:link {
in the Additional CSS field, and this applied underlines to only the body text as desired. I'm guessing that Themler is applying that attribute to a:link which makes it global.
I experienced the same problem as @Rogier I wanted links in body text to be underlined. When I went to Design/More Styles/Text to set Links to be underlined, Themler applied the underline attribute GLOBALLY to ALL links. So links in all the Headings, Lists, Button, etc. got underlines, which is not what I want. The attached image shows the Text flyout, with underline selected for Links. As you can see, the underline attribute is applied Globally. My workaround was to put p a:link { text-decoration: underline; } in the Additional CSS field, and this applied underlines to only the body text as desired. I'm guessing that Themler is applying that attribute to a:link which makes it global.
Elmar
Elmar posted this 04 April 2017
I am still experiencing this bug. The workaround is no solution. Please fix asap.
Support Team posted this 04 April 2017
That is actually not a bug. If you set the link style under the Design tab, that style is applied to all the links, meant all elements using the <a> tag. Those are headings, links and so on. To edit the link style in, for example, the post content only, you need to open Posts control >> Post Content >> More Styles >> Text >> Link and set the desired options.
You can describe your problem in more details so we could help you.
Hi, That is actually not a bug. If you set the link style under the Design tab, that style is applied to all the links, meant all elements using the `<a>` tag. Those are headings, links and so on. To edit the link style in, for example, the post content only, you need to open Posts control >> Post Content >> More Styles >> Text >> Link and set the desired options. You can describe your problem in more details so we could help you. Sincerely, Hella
Elmar
Elmar posted this 12 April 2017
Thanks I think that was what i was looking for.
Support Team posted this 13 April 2017
chinahousehold
chinahousehold posted this 08 March 2026
https://www.hssolar.cn
https://www.xcspa.com
https://www.bambooflooring.net
https://allmy.bio/bothbest
http://scenarch.com/scenarios/4107
https://codoc.jp/sites/bothbest/entries/TV91FQ7dtA
https://naya.com.np/post/p17727151530if6p
https://ameblo.jp/japanbamboo/entry-12958778757.html
https://www.expatriates.com/cls/62745422.html
https://forumtransportu.pl/forum/temat/36017
https://ticketme.io/account/bothbest
https://sngine.fr/blogs/34945/The-Most-Common-Mistakes-When-Buying-Bamboo-Plywood-Sheets
https://bothbest.firstory.io/posts/bamboo-panels-for-cabinets-pros-cons-and-design-ideas-v6rxmdjb488k
http://resurrection.bungie.org/forum/index.pl?profile=bothbest
https://bambooflooring.wowlaunch.com/
https://bambooflooring.wowlaunch.com/forums/viewtopic.php?t=12222880&gid=617589
https://bambooflooring.alboompro.com/post/how-bamboo-plywood-is-made-from-stalk-to-strong-structural-panel
https://arizonaadam.com/forum/topic/moisture-resistance-in-bamboo-plywood-how-it-really-performs/
https://mypaper.pchome.com.tw/bothbest/post/1383388958
https://kumu.io/bothbest/bamboo-beams-are-they-strong-enough-for-structural-projects
https://qrfonline.qrfmag.com/qrfswap/viewtopic.php?t=42846
https://www.hssolar.cn/news-49.html
https://docs.datananas.com/discuss/69aa7e25ba04f74bbc8b9531
https://roughstuffmedia.activeboard.com/t72588798/bamboo-lumber-vs-hardwood-which-performs-better/
https://bambooflooring.univer.se/how-to-maintain-and-finish-bamboo-panels-for-long-lasting-beauty
https://www.theconsumersfeedback.com/guestpost/bamboo-plywood-sheets-prices-in-2026-what-consumers-need-to-know
https://bamboo-flooring.jimdosite.com/news/
https://bamboo-flooring.jimdosite.com/news/how-to-maintain-and-finish-bamboo-panels-for-long-lasting-beauty/
https://www.thefreeadforum.com/postclassifieds/for-sale/home-furniture-garden/classifieds_for_free/bamboo-plywood-explained-types-grades-and-uses_i6322514/classifieds-for-free/los-angeles
https://www.efunda.com/members/people/show_people.cfm?Usr=bothbest
https://www.civocracy.org/user/48252
https://www.sooplive.co.kr/station/bothbest/post/188962791
https://bamboochopsticks.storeinfo.jp/posts/58613464
https://bamboodecking.themedia.jp/posts/58613470
https://bambooplywood.localinfo.jp/posts/58613468
https://chinabamboo.therestaurant.jp/posts/58613471
https://bambooflooring.shopinfo.jp/posts/58613473
https://bambooflooring.theblog.me/posts/58613478
https://japanbamboo.storeinfo.jp/posts/58613483
https://bothbest.amebaownd.com/posts/58613487
https://hackmd.io/@chinabamboo/B1lK4T-YFWg
https://md.sigma2.no/s/C-Mug7Yid
https://zumpadpro.zum.de/s/r1WD0-FF-x
https://md.coredump.ch/s/pHOdUSfOG
https://www.frenchwomenorg.com/read-blog/29992
https://www.glbrain.com/index.php?r=content/view&id=48731
https://ssn.so/forums/munpia-contest/topic/78773/
https://circle-book.com/circles/16446/blogs/108876
https://www.hssolar.cn https://www.xcspa.com https://www.bambooflooring.net https://allmy.bio/bothbest http://scenarch.com/scenarios/4107 https://codoc.jp/sites/bothbest/entries/TV91FQ7dtA https://naya.com.np/post/p17727151530if6p https://ameblo.jp/japanbamboo/entry-12958778757.html https://www.expatriates.com/cls/62745422.html https://forumtransportu.pl/forum/temat/36017 https://ticketme.io/account/bothbest https://sngine.fr/blogs/34945/The-Most-Common-Mistakes-When-Buying-Bamboo-Plywood-Sheets https://bothbest.firstory.io/posts/bamboo-panels-for-cabinets-pros-cons-and-design-ideas-v6rxmdjb488k http://resurrection.bungie.org/forum/index.pl?profile=bothbest https://bambooflooring.wowlaunch.com/ https://bambooflooring.wowlaunch.com/forums/viewtopic.php?t=12222880&gid=617589 https://bambooflooring.alboompro.com/post/how-bamboo-plywood-is-made-from-stalk-to-strong-structural-panel https://arizonaadam.com/forum/topic/moisture-resistance-in-bamboo-plywood-how-it-really-performs/ https://mypaper.pchome.com.tw/bothbest/post/1383388958 https://kumu.io/bothbest/bamboo-beams-are-they-strong-enough-for-structural-projects https://qrfonline.qrfmag.com/qrfswap/viewtopic.php?t=42846 https://www.hssolar.cn/news-49.html https://docs.datananas.com/discuss/69aa7e25ba04f74bbc8b9531 https://roughstuffmedia.activeboard.com/t72588798/bamboo-lumber-vs-hardwood-which-performs-better/ https://bambooflooring.univer.se/how-to-maintain-and-finish-bamboo-panels-for-long-lasting-beauty https://www.theconsumersfeedback.com/guestpost/bamboo-plywood-sheets-prices-in-2026-what-consumers-need-to-know https://bamboo-flooring.jimdosite.com/news/ https://bamboo-flooring.jimdosite.com/news/how-to-maintain-and-finish-bamboo-panels-for-long-lasting-beauty/ https://www.thefreeadforum.com/postclassifieds/for-sale/home-furniture-garden/classifieds_for_free/bamboo-plywood-explained-types-grades-and-uses_i6322514/classifieds-for-free/los-angeles https://www.efunda.com/members/people/show_people.cfm?Usr=bothbest https://www.civocracy.org/user/48252 https://www.sooplive.co.kr/station/bothbest/post/188962791 https://bamboochopsticks.storeinfo.jp/posts/58613464 https://bamboodecking.themedia.jp/posts/58613470 https://bambooplywood.localinfo.jp/posts/58613468 https://chinabamboo.therestaurant.jp/posts/58613471 https://bambooflooring.shopinfo.jp/posts/58613473 https://bambooflooring.theblog.me/posts/58613478 https://japanbamboo.storeinfo.jp/posts/58613483 https://bothbest.amebaownd.com/posts/58613487 https://hackmd.io/@chinabamboo/B1lK4T-YFWg https://md.sigma2.no/s/C-Mug7Yid https://zumpadpro.zum.de/s/r1WD0-FF-x https://md.coredump.ch/s/pHOdUSfOG https://www.frenchwomenorg.com/read-blog/29992 https://www.glbrain.com/index.php?r=content/view&id=48731 https://ssn.so/forums/munpia-contest/topic/78773/ https://circle-book.com/circles/16446/blogs/108876
