side menu/vertical menu
jackymoore10
jackymoore10 posted this 19 October 2016
How do I go about creating a vertical menu on the left hand side of my site in themler?
Will it be responsive?
Can you have a top men and an vertical menu?
Hi How do I go about creating a vertical menu on the left hand side of my site in themler? Will it be responsive? Can you have a top men and an vertical menu? Thank you
Support Team posted this 19 October 2016
You work with Themler for Joomla, right?
Please follow the article on creating a Vertical Menu in Joomla:
http://answers.themler.com/articles/6643/how-to-create-vertical-menus-in-joomla
Yes, you can add it independent on the horizontal menu, so there can be several menus on your website. To put the vertical menu on the left side, add the module position for the vertical menu into the left sidebar.
Responsive behaviour can be set in the Vertical Menu tab >> Responsive.
Hello, You work with Themler for Joomla, right? Please follow the article on creating a Vertical Menu in Joomla: http://answers.themler.com/articles/6643/how-to-create-vertical-menus-in-joomla Yes, you can add it independent on the horizontal menu, so there can be several menus on your website. To put the vertical menu on the left side, add the module position for the vertical menu into the left sidebar. Responsive behaviour can be set in the Vertical Menu tab >> Responsive. Sincerely, Nettie, BillionDigital Team
herresnh
herresnh posted this 22 June 2018
I did what is recommended and can't seem to figure out how to get it to be a vertical menu. Still displaying as a block.
Hi, I did what is recommended and can't seem to figure out how to get it to be a vertical menu. Still displaying as a block.
Support Team posted this 23 June 2018
Make sure that you have added the vmenuа class suffix correctly with the space before it. In case that does not help, provide an access to the site back end in the new private case.
Hi, Make sure that you have added the `vmenu`а class suffix correctly with the space before it. In case that does not help, provide an access to the site back end in the new private case. Sincerely, Hella
