Different metadata on the various pages?
Samuele
Samuele posted this 19 October 2016
I am aware of the fact that I can add my metadata inside the window 'Additional Head HTML' under the page setting, what I would like to know is if it is possible to insert different metadata on the various pages. At the moment when I change the metadata the change will affect all the pages.... Is there a way to do this?
Sam
Hi, I am aware of the fact that I can add my metadata inside the window 'Additional Head HTML' under the page setting, what I would like to know is if it is possible to insert different metadata on the various pages. At the moment when I change the metadata the change will affect all the pages.... Is there a way to do this? Thank you Sam
Support Team posted this 20 October 2016
In Themler there is no possibility to add different metadata for each page. I suggest you to search for the plug-in that will implement such functionality for your CMS.
Hi, In Themler there is no possibility to add different metadata for each page. I suggest you to search for the plug-in that will implement such functionality for your CMS. Sincerely, Hella
Samuele
Samuele posted this 28 October 2016
I have followed your advice and installed Yoast (which it's one of the biggest SEO plugin available for Wordpress), this way I can inputs keywords in the various pages but somehow the plugin cannot read the text and titles that I've written on my static pages using directly Themler. The plugin can only see the contents that I might create within Wordpress editor but not the on created with Themler.
I have asked to the Yoast developers the reason for this and they have replied me:
"Our plugin analyzes the default WordPress content areas. If the analysis does not pick up all of your information, you are likely adding content outside of the default editor. Some plugins and themes, like page builders or visual composers, do not share their content with our analysis feature.
If you are using a plugin or theme that doesn’t send their content to our page analysis, please reach out the developer and ask them about adding the functionality to their code. This KB article will help them with the implementation: Can I add data to the page analysis?"
My question is, will Themler themes not send any of their contents to any SEO plugin that I can use with Wordpress or it is an isolated problem with Yoast? If it is a problem only with Yoast, can someone in this forum suggest me some good Wordpess plugin that is able to read also the contents that I write with Themler directly on the theme?
Samuele
Hi, I have followed your advice and installed Yoast (which it's one of the biggest SEO plugin available for Wordpress), this way I can inputs keywords in the various pages but somehow the plugin cannot read the text and titles that I've written on my static pages using directly Themler. The plugin can only see the contents that I might create within Wordpress editor but not the on created with Themler. I have asked to the Yoast developers the reason for this and they have replied me: *"Our plugin analyzes the default WordPress content areas. If the analysis does not pick up all of your information, you are likely adding content outside of the default editor. Some plugins and themes, like page builders or visual composers, do not share their content with our analysis feature. If you are using a plugin or theme that doesn’t send their content to our page analysis, please reach out the developer and ask them about adding the functionality to their code. This KB article will help them with the implementation: Can I add data to the page analysis?"* My question is, will Themler themes not send any of their contents to any SEO plugin that I can use with Wordpress or it is an isolated problem with Yoast? If it is a problem only with Yoast, can someone in this forum suggest me some good Wordpess plugin that is able to read also the contents that I write with Themler directly on the theme? Thanks Samuele
Support Team posted this 31 October 2016
Hello Samuele,
there's no special options in Themler that allows or disallows to send anything to SEO plugins.
the content of the page in Themler theme consists of the static and dynamic parts. You may see the dynamic part in Themler in green border. This is WP content: pages, posts, widgets. It could be accessed and edited from WP admin and Themler.
The static content is in blue border in Themler. This content is part of the theme and it cannot be accessed from WP admin back end. I suppose that this content cannot be "accessed" by SEO plugins.
As workaround you may consider using the WP Widget Areas instead of Text controls and add text type widgets in WP.
Hello Samuele, there's no special options in Themler that allows or disallows to send anything to SEO plugins. the content of the page in Themler theme consists of the static and dynamic parts. You may see the dynamic part in Themler in green border. This is WP content: pages, posts, widgets. It could be accessed and edited from WP admin and Themler. The static content is in blue border in Themler. This content is part of the theme and it cannot be accessed from WP admin back end. I suppose that this content cannot be "accessed" by SEO plugins. As workaround you may consider using the WP Widget Areas instead of Text controls and add text type widgets in WP. regards, Aileen
Samuele
Samuele posted this 01 November 2016
Thank you for answering and for suggesting a workaround to the issue. It's just a bit of a let-down that at this point all the beautiful pre-designed sections that Themler offers cannot be used unless you decide to sacrifice your SEO for those sections.
It would be interesting to know how Google handles all the static contents that belong to the theme....
Thank s
Samuele
Thank you for answering and for suggesting a workaround to the issue. It's just a bit of a let-down that at this point all the beautiful pre-designed sections that Themler offers cannot be used unless you decide to sacrifice your SEO for those sections. It would be interesting to know how Google handles all the static contents that belong to the theme.... Thank s Samuele
Support Team posted this 01 November 2016
I assume that the search engines will grab the static content of your site the same as the content added from the admin panel, it's a simple HTML for the search spiders. But the issue is that you can not handle this static content with your SEO plug-ins.
Hi, I assume that the search engines will grab the static content of your site the same as the content added from the admin panel, it's a simple HTML for the search spiders. But the issue is that you can not handle this static content with your SEO plug-ins. Sincerely, Hella
ImanAlimi
ImanAlimi posted this 25 June 2017
I have the same problem as Samuele has.
I need to add different meta descriptions and keywords in each page.
Please help.
Iman
Hi, I have the same problem as Samuele has. I need to add different meta descriptions and keywords in each page. Please help. Thanks, Iman
Support Team posted this 26 June 2017
ImanAlimi,
According to our records you're using WordPress. WordPress has a lot of existing plugins to manage SEO and set page metadata. You can use any of them.
ImanAlimi, According to our records you're using WordPress. WordPress has a lot of existing plugins to manage SEO and set page metadata. You can use any of them. Thank you, Olivia
