problems with gsm lay out
arawolf
arawolf posted this 23 October 2016
The site klusjeskesteloot.be works perfect om full screen and tablet , but on the phone lay out i get many error message "
Error displaying the error page: Call to a member function containsModules() on null: Artikel niet gevonden" when i go to different pages.
The site klusjeskesteloot.be works perfect om full screen and tablet , but on the phone lay out i get many error message " Error displaying the error page: Call to a member function containsModules() on null: Artikel niet gevonden" when i go to different pages.
10 Comments
Support Team posted this 24 October 2016
Indeed, I see the error, looks like a data base issue. Please try to install any other non-Themler theme and check if the issue persists.
Hi, Indeed, I see the error, looks like a data base issue. Please try to install any other non-Themler theme and check if the issue persists. Sincerely, Hella
arawolf
arawolf posted this 24 October 2016
Hella it seems a problem with the buttons. The other links ( menu) works fine. But the buttonlins gives the error.
Also on the dektop lay out.
Hella it seems a problem with the buttons. The other links ( menu) works fine. But the buttonlins gives the error. Also on the dektop lay out.
arawolf
arawolf posted this 25 October 2016
Now it's also a problem on the tablet lay out.
Support Team posted this 26 October 2016
Now the site works just fine on my end.
Hi, Now the site works just fine on my end. Sincerely, Hella
arawolf
arawolf posted this 26 October 2016
Sorry hella on my phone the result is the same. The buttons gives the errors
The Button is a simple link with href http://klusjeskesteloot.be/index.php/contact
The menu item has the following href: http://klusjeskesteloot.be/index.php/contact-formulier
Are you sure that you have joomla page with the following URL?
If not please corrent the link source.
Hi, The Button is a simple link with href `http://klusjeskesteloot.be/index.php/contact` The menu item has the following href: `http://klusjeskesteloot.be/index.php/contact-formulier` Are you sure that you have joomla page with the following URL? `http://klusjeskesteloot.be/index.php/contact` If not please corrent the link source. Thank you, Olivia
arawolf
Thnxs i change the links everythings seems fine exept the form. It doesnt show in the phone lay out
Support Team posted this 28 October 2016
Hello Kris,
please provide access to your Joomla admin back end so we could open and check the theme in Themler
Hello Kris, please provide access to your Joomla admin back end so we could open and check the theme in Themler regards, Aileen
arawolf
arawolf posted this 28 October 2016
User pasword test
User pasword test
Support Team posted this 31 October 2016
Hello Kris,
to make the form visible in Phone mode you need to enable visible option for the Columns in Phone mode
Hello Kris, to make the form visible in Phone mode you need to enable visible option for the Columns in Phone mode !EnableColumns.png! regards, Aileen
