Prestashop menu
Linkebel
Linkebel posted this 27 October 2016
  • Is it possible that a Prestashop menu to have the submenu by clicking?
  • Is it possible to put an image which represents the submenu as in the image below (by css or other)?
http://postimg.org/image/ldd7fvzl5/
http://postimg.org/image/6sf4o6fmv/
Thank you for your reply
Hello, - Is it possible that a Prestashop menu to have the submenu by clicking? - Is it possible to put an image which represents the submenu as in the image below (by css or other)? http://postimg.org/image/ldd7fvzl5/ http://postimg.org/image/6sf4o6fmv/ Thank you for your reply
Linkebel
Linkebel posted this 28 October 2016
Up !!!!
Up !!!!
Support Team posted this 28 October 2016
The megamenu option is available, go to Horizontal Menu >> Type and select megamenu. Note, that it works only when you have 3 menu levels or more. But there is no possibility to insert the image into menu.
Hi, The megamenu option is available, go to Horizontal Menu >> Type and select megamenu. Note, that it works only when you have 3 menu levels or more. But there is no possibility to insert the image into menu. Sincerely, Hella
