No More Easy
Escambio
Escambio posted this 28 October 2016
I work with artisteer since 2013 and was making sites with Joomla.
Now I don`t use Joomla anymore because is a continue developing CMS .... for one site it is ok... but not for anyone that need more than ten.
The reasong I write is to tell you something that maybe nobody see.
Your system is growing to complicate.
I and also a bit disapoint because I could make great site with your software.. but I tried and the results are not what I want.
I change all my sites to HTML.. and I will make some with joomla again.. but my question is: why so difficult ?
Now I use Mobirise from mobirise.com to make sites.... In HTML .. and works very fast to make sites.
I WANT TO USE THEMLER ... and when I export the site I want to see what I made on PC , tablets or phones.
Please take this as constructive opinion.
MAKE THEMLER FOR HTML EASEAR.
Thank you for your time.
Regards.
I work with artisteer since 2013 and was making sites with Joomla. Now I don`t use Joomla anymore because is a continue developing CMS .... for one site it is ok... but not for anyone that need more than ten. The reasong I write is to tell you something that maybe nobody see. Your system is growing to complicate. I and also a bit disapoint because I could make great site with your software.. but I tried and the results are not what I want. I change all my sites to HTML.. and I will make some with joomla again.. but my question is: why so difficult ? Now I use Mobirise from mobirise.com to make sites.... In HTML .. and works very fast to make sites. I WANT TO USE THEMLER ... and when I export the site I want to see what I made on PC , tablets or phones. Please take this as constructive opinion. MAKE THEMLER FOR HTML EASEAR. Thank you for your time. Regards.
Support Team posted this 28 October 2016
Thanks for your feedback. Maybe you could be more precise about what exactly is complicated for you in Themler.
Hi, Thanks for your feedback. Maybe you could be more precise about what exactly is complicated for you in Themler. Sincerely, Hella
Escambio
Escambio posted this 29 October 2016
To work with themler is not difficult.
When export have to care about four different divices your self and this shoul be automatic.
If you import anything from library .. at the end should look like what you see... but my last experience was not like this.
For content manager systems works better as for html.
I will make the same site in themler and will see if there is any change on the new versions.
Themler is very good... I will see the end sites and how they look on different divices so we can know where to make changes or not.
Thank you for your reply.
Regards.
To work with themler is not difficult. When export have to care about four different divices your self and this shoul be automatic. If you import anything from library .. at the end should look like what you see... but my last experience was not like this. For content manager systems works better as for html. I will make the same site in themler and will see if there is any change on the new versions. Themler is very good... I will see the end sites and how they look on different divices so we can know where to make changes or not. Thank you for your reply. Regards.
Support Team posted this 30 October 2016
If you have any exact issues, please explain them in more details so we could help.
Hi, If you have any exact issues, please explain them in more details so we could help. Sincerely, Hella
