posted this
02 November 2016
if product categories can be shown like products. For example 4 product colums and have a page with only categories shown for example into 4 columns and when click into each category appers the products.
In general yes, you can create such layout. In case you only need a categories you can set the following Products Display settings in WP:
NOTE: in this case you will not see the products on the Products template in Themler until you open category page by right click >> Open link in Themler. As alternative solution you can set "Show Categories and Products", configure products and then swith display settings to the desired value.
And add Subcategories in Themler:
Another thing I would like to know to evaluate to buy themler is if its possible too to click over an image and when clicked only appears a second image not details. The main product image is switched by other image only if I click over the product image.
Themler supports only one behaviour of the product images:
- on the Products template product image is a link to the product details.
- on the product Details template the product Image is not clickable but Product Thumbnails control switches Product image by click. Also when you're using large image Product image has CloudZoom effect. That's all.
If you know how to implement desired behaviour by custom code you a use CMS Code control instead of the product image.
!woo-categories.png!
!woo-categories-themler.png!
If you know how to implement desired behaviour by custom code you a use *CMS Code* control instead of the product image.
