What mistake is this now ??
Blocked frame with origin "http://127.0.0.1:12080" Accessing from the cross-origin frame
It appeared this error message when you click products, see the asquivo attached.
Each time a different error ...... strange, system instability .. insecurity to use.
Att..
Amilcar
What mistake is this now ?? Blocked frame with origin "http://127.0.0.1:12080" Accessing from the cross-origin frame It appeared this error message when you click products, see the asquivo attached. Each time a different error ...... strange, system instability .. insecurity to use. Att.. Amilcar
