I'm working with the latest Themler beta and on a Joomla CMS. I have my header divided into 3 columns. I can insert (drag and drop) items in a 'row' that goes above or below whatever item is already in a column, that process is pretty straight forward. But what I'd like to do is have multiple columns inside the bottom row (2nd row) while the top row maintains it's one column layout. So the bottom row has multiple columns and the top one, like you can do with an HTML table with multiple columns. You can merge the top row cells into one cell, with the 2nd row having multiple columns. Can I do this in themler and if so how?
The purpose of me asking is that I want to animate several images in the 2nd row of my center column, but when you insert more than one image into a column it goes above or below into it's own row. I'm wanting to place images to the right and left of each other and animate them individually.
I'm working with the latest Themler beta and on a Joomla CMS. I have my header divided into 3 columns. I can insert (drag and drop) items in a 'row' that goes above or below whatever item is already in a column, that process is pretty straight forward. But what I'd like to do is have multiple columns inside the bottom row (2nd row) while the top row maintains it's one column layout. So the bottom row has multiple columns and the top one, like you can do with an HTML table with multiple columns. You can merge the top row cells into one cell, with the 2nd row having multiple columns. Can I do this in themler and if so how? The purpose of me asking is that I want to animate several images in the 2nd row of my center column, but when you insert more than one image into a column it goes above or below into it's own row. I'm wanting to place images to the right and left of each other and animate them individually.
