I am building a website for a client. After I am finished building it, I want to enable the users to edit the slider without having to acces themler (so they can't mess things up).
Is this possible?
Thanks in advance.
Wesley
Is this possible?
Thanks in advance.
Wesley
No, it's not possible. You can consider using another slider from the third-party extensions that will allow editing inside the CMS admin panel.
What is the slider if the client can not even change the ????
It's really not serious
What is the slider if the client can not even change the ???? It's really not seriousHi,
Slider is a static component of the theme so it can be changed in the design only. Please consider using the third-party plug-ins for the slider that should be editable by the customer.
I made short tutorial. It is not so difficult if you have ACF PRO licence. If dont adapt code to some other repeater field. Or to any gallery field, and how to pull images from gallery.
http://answers.themler.com/questions/125207/tutorial-easy-editable-th-slider-by-user?page=1
I made short tutorial. It is not so difficult if you have ACF PRO licence. If dont adapt code to some other repeater field. Or to any gallery field, and how to pull images from gallery. http://answers.themler.com/questions/125207/tutorial-easy-editable-th-slider-by-user?page=1
