Themler Active Menu incorrect in Wordpress
len
len posted this 07 November 2016
On the Wordpress home page, the active menu highlight is on the top level of a submenu item, with the non-clickable URL set to either a blank or # (the Wordpress recommended way).
Menu structure is:
Home
Information (with submenu items) page 1, page 2
The top level "Information" item is a custom link in Wordpress, with the URL set to either a blank or # (the Wordpress recommended way).
On the Home page, the Information item is highlighted as active irrespective is the blank or # in the URL.
In Artisteer and previous versions of Themler, setting the top level to # has always worked, with the correct top level highlighted.
There is another Answers thread with a similar issue, that suggests setting the URL to www. This does solve the highlighting of the active item, but if the website visitor clicks the top level link (which has no page associated with it) it results in a page not found. This is not a solution. http://answers.themler.com/questions/68559/active-menu-item-not-displaying-in-wordpress
How can this be fixed please?
On the Wordpress home page, the active menu highlight is on the top level of a submenu item, with the non-clickable URL set to either a blank or # (the Wordpress recommended way). Menu structure is: Home Information (with submenu items) page 1, page 2 The top level "Information" item is a custom link in Wordpress, with the URL set to either a blank or # (the Wordpress recommended way). On the Home page, the Information item is highlighted as active irrespective is the blank or # in the URL. In Artisteer and previous versions of Themler, setting the top level to # has always worked, with the correct top level highlighted. There is another Answers thread with a similar issue, that suggests setting the URL to www. This does solve the highlighting of the active item, but if the website visitor clicks the top level link (which has no page associated with it) it results in a page not found. This is not a solution. http://answers.themler.com/questions/68559/active-menu-item-not-displaying-in-wordpress How can this be fixed please?
8 Comments
Support Team posted this 07 November 2016
Please try updating to the latest Beta version. The issue should be fixed there, the behaviour should be correct with default settings (without any additional changes). You may need to check the box next to "Get Beta updates" in your profile to receive the Beta update notification. After installing the Beta update you may uncheck the box at an time.
Please let us know if the issue is still present.
Hello, Please try updating to the latest Beta version. The issue should be fixed there, the behaviour should be correct with default settings (without any additional changes). You may need to check the box next to "Get Beta updates" in your profile to receive the Beta update notification. After installing the Beta update you may uncheck the box at an time. Please let us know if the issue is still present. Sincerely, Nettie, BillionDigital Team
len
Is Solution
That was a very quick response.
Done, and yes v.355 has fixed it, thanks.
LenW
Nettie That was a very quick response. Done, and yes v.355 has fixed it, thanks. LenW
Len, you are welcome! Please feel free to contact us in any other case.
Len, you are welcome! Please feel free to contact us in any other case. Sincerely, Nettie, BillionDigital Team
Orange Gorilla
Orange Gorilla posted this 24 January 2022
Is this a Themler issue again? beacuse i'm dealing with it within the current version.
Support Team posted this 24 January 2022
Are you using Themler v547?
And your WordPress is also the latest version?
Hello, Are you using Themler v547? And your WordPress is also the latest version? Gina Themler Support
Orange Gorilla
Orange Gorilla posted this 25 January 2022
Hi> Hello,
yes, last beta version.
And latest worpress vesion (5.8.3)
Hi> Hello, > > Are you using Themler v547? > > And your WordPress is also the latest version? > > Gina > Themler Support Hi, yes, last beta version. And latest worpress vesion (5.8.3)
Orange Gorilla
Orange Gorilla posted this 27 January 2022
Someone any idea how to fix this?
Kolkata Aira
Kolkata Aira posted this 28 January 2022
Good post and to be here
