I want to save custom template to use on another WP site. How do you do that.
Many thanks
jagath
Many thanks
jagath
You can export your theme with content or without content then import that theme from another WordPress site. While you import theme then it will ask you are you want to import content or not. If you want to use old site content then click yes if not interest then click no. Remember for editing your theme you must need to login themler from new site, without login you or your client can operate normal site as like other premium or free theme. thank you.
You can export your theme with content or without content then import that theme from another WordPress site. While you import theme then it will ask you are you want to import content or not. If you want to use old site content then click yes if not interest then click no. Remember for editing your theme you must need to login themler from new site, without login you or your client can operate normal site as like other premium or free theme. thank you.You can export your theme with content or without content then import that theme from another WordPress site. While you import theme then it will ask you are you want to import content or not. If you want to use old site content then click yes if not interest then click no. Remember for editing your theme you must need to login themler from new site, without login you or your client can operate normal site as like other premium or free theme. thank you.
Thank you for quick response,
Please excuse for my ignorance. What I meant was, I want just one custom template from the old site to be used in another site. Do I have to import the entire theme ZIP file from the old site and import it to the new site to be able to use just one custom file?
Thanks again
jagath
this article describes how to import and export WP theme
http://answers.themler.com/articles/72522/import-export-content
please follow it
