Is there any options in Themler to adjust the long left column in prestashop
support12
support12 posted this 09 November 2016
Is there any options in Themler to adjust the long left column in prestashop like the left hook colour and filter etc. Can you suggestions me.
8 Comments
Support Team posted this 09 November 2016
Sorry, the question is not clear. Could you please attach a marked screen shot demonstrating what you want to edit.
Hi, Sorry, the question is not clear. Could you please attach a marked screen shot demonstrating what you want to edit. Sincerely, Hella
support12
support12 posted this 10 November 2016
When you open libroox.com in mobile and pick one product and check out you will lots of categories and others stuff comes in screen so I want this things to be come in drop down or responsive mode like that. You can see -www. jabong.com in mobile also.
support12
And please find the menu bar I have attached in screen shot it not properly align and I need it in the same position only I want it only on the same position but the the drop sown menu should come in the left align.
support12
And one more
1) how to disable categories in checkout options.
2) How to make drop menu for items added in cart in mobile mode.
And one more 1) how to disable categories in checkout options. 2) How to make drop menu for items added in cart in mobile mode.
support12
support12 posted this 11 November 2016
Waiting for the reply Support.
support12
support12 posted this 12 November 2016
This is very urgent Support Team . I am waiting for the response.
support12
support12 posted this 14 November 2016
This is really embrassing at all how long we have to wait now to get this solutions.
Support Team posted this 16 November 2016
Sorry for the delay.
The feature you're referring too should be a part of the module, not the sidebar.
Themler sidebar itself cannot be collapsed in the described way.
As I can see you hide the whole block in the phone mode. As alternative solution you can try adding one mode menu for Phone mode to the desired place in the Columns control you added for Phone mode.
Could you please explain in more details what categories you're referring to?
Unfortunately Cart Link control does not support such feature.
Themler Team
Hi, Sorry for the delay. > When you open libroox.com in mobile and pick one product and check out you will lots of categories and others stuff comes in screen so I want this things to be come in drop down or responsive mode like that. You can see -www. jabong.com in mobile also. The feature you're referring too should be a part of the module, not the sidebar. Themler sidebar itself cannot be collapsed in the described way. > And please find the menu bar I have attached in screen shot it not properly align and I need it in the same position only I want it only on the same position but the the drop sown menu should come in the left align. As I can see you hide the whole block in the phone mode. As alternative solution you can try adding one mode menu for Phone mode to the desired place in the Columns control you added for Phone mode. > 1) how to disable categories in checkout options. Could you please explain in more details what categories you're referring to? > 2) How to make drop menu for items added in cart in mobile mode. Unfortunately Cart Link control does not support such feature. Thank you, Themler Team
