Themler export from Wordpress installation: file location
jens25
jens25 posted this 11 November 2016
I have an Wordpress site where I have installed a theme made in Themler.
Then I have installed Themler Tools so that I can edit my pages in Themler.
But when I want to export my changes I can find the exported file.
It ask me for a name but when I export it does not ask for a location.
So my question is, where does it export this zip file to?
I have an Wordpress site where I have installed a theme made in Themler. Then I have installed Themler Tools so that I can edit my pages in Themler. But when I want to export my changes I can find the exported file. It ask me for a name but when I export it does not ask for a location. So my question is, where does it export this zip file to?
138 Comments
Support Team posted this 11 November 2016
As a rule, the exported zip goes to the default browser download location. If a browser has a setting to ask where to download it to, it should do it on export as well. If there is some default location, it will save the theme into there without asking. The location can be seen or changed in browser settings. For example, in Chrome:
https://support.google.com/chrome/answer/95759?co=GENIE.Platform%3DDesktop&hl=en
Hello, As a rule, the exported zip goes to the default browser download location. If a browser has a setting to ask where to download it to, it should do it on export as well. If there is some default location, it will save the theme into there without asking. The location can be seen or changed in browser settings. For example, in Chrome: https://support.google.com/chrome/answer/95759?co=GENIE.Platform%3DDesktop&hl=en Sincerely, Nettie, BillionDigital Team
davidtrew835
davidtrew835 posted this 21 February 2025
https://support.google.com/chrome/answer/95759?co=GENIE.Platform%3DDesktop&hl=en geometry dash lite
Thanks for your answer. This is what I'm looking for.
> As a rule, the exported zip goes to the default browser download location. If a browser has a setting to ask where to download it to, it should do it on export as well. If there is some default location, it will save the theme into there without asking. The location can be seen or changed in browser settings. For example, in Chrome: https://support.google.com/chrome/answer/95759?co=GENIE.Platform%3DDesktop&hl=en [geometry dash lite][1] Thanks for your answer. This is what I'm looking for. [1]: https://geometry-dash-lite.com
sunf3600
sunf3600 posted this 26 February 2025
Download the latest gbwhata APK v18.30 to access advanced messaging features, enhanced privacy options, and customizable themes.
Download the latest [gbwhata][1] APK v18.30 to access advanced messaging features, enhanced privacy options, and customizable themes. [1]: https://gbwhata.net
willjacksmith42
willjacksmith42 posted this 23 May 2025
When you're using Themler within WordPress and you export a theme, Themler generates a ZIP file of the theme. However, the export behavior depends on how you’re using Themler — standalone (desktop) or through the browser in WordPress.
If You're Using Themler via WordPress (Browser-Based)
When you export a theme through the Themler Tools inside WordPress:
  • The ZIP file is not automatically downloaded.
  • Instead, it's saved on your server, usually within the theme’s folder, or made available for manual download.
Here’s how to find it:
✅ Steps to locate the exported theme ZIP file:
  1. Log in to your WordPress admin panel.
  2. Go to Appearance > Themes.
  3. Select the Themler Tools menu or any similar Themler-related entry.
  4. Look for an "Export" or "Manage Exports" option — Themler should list exported versions/themes.
  5. You may find a download link for the exported ZIP file there.
🔍 Or check via FTP / File Manager:
Connect to your site via FTP or use your hosting's File Manager and look in:
/wp-content/themes/
or sometimes in:
/wp-content/themler/
or a similar directory like:
/wp-content/uploads/themler/
Look for ZIP files or folders named based on your export name.
If You're Using Themler Desktop App
If you’re editing the theme using the desktop version of Themler, then the ZIP file is usually exported to:
Documents\Themler\Export\
on your local machine (Windows).
If you’re unsure which version you're using (desktop vs browser plugin), let me know, and I can guide you more specifically.
Learn How to see lyrics on Spotify
When you're using **Themler** within WordPress and you **export a theme**, Themler generates a **ZIP file** of the theme. However, the export behavior depends on **how you’re using Themler** — standalone (desktop) or through the browser in WordPress. ### If You're Using Themler via WordPress (Browser-Based) When you **export a theme** through the Themler Tools inside WordPress: * The **ZIP file is not automatically downloaded**. * Instead, it's **saved on your server**, usually within the **theme’s folder**, or made available for **manual download**. Here’s how to find it: #### ✅ Steps to locate the exported theme ZIP file: 1. **Log in to your WordPress admin panel.** 2. Go to **Appearance > Themes**. 3. Select the **Themler Tools** menu or any similar Themler-related entry. 4. Look for an **"Export"** or **"Manage Exports"** option — Themler should list exported versions/themes. 5. You may find a **download link** for the exported ZIP file there. #### 🔍 Or check via FTP / File Manager: Connect to your site via FTP or use your hosting's File Manager and look in: ``` /wp-content/themes/ ``` or sometimes in: ``` /wp-content/themler/ ``` or a similar directory like: ``` /wp-content/uploads/themler/ ``` Look for ZIP files or folders named based on your export name. --- ### If You're Using Themler Desktop App If you’re editing the theme using the **desktop version of Themler**, then the ZIP file is usually exported to: ``` Documents\Themler\Export\ ``` on your local machine (Windows). --- If you’re unsure which version you're using (desktop vs browser plugin), let me know, and I can guide you more specifically. Learn [How to see lyrics on Spotify][1] [1]: https://spotihax.com/how-to-see-lyrics-on-spotify/
informationofworld2
informationofworld2 posted this 08 July 2025
youtube automation salary https://www.nexlev.io/ways-to-make-money-with-youtube-automation is the process of simplifying and speeding up channel management by using software or hired help. It reduces the need for hands-on work in areas like content production, posting, and optimization. This approach allows creators to grow their channels more efficiently with less daily involvement.
joicezhan1107
joicezhan1107 posted this 10 July 2025
Get the latest GBWhatsApp APK v18.50 at :waplusmods to enjoy improved messaging capabilities, stronger privacy controls, and a variety of customizable themes.
Get the latest GBWhatsApp APK v18.50 at :[waplusmods][1] to enjoy improved messaging capabilities, stronger privacy controls, and a variety of customizable themes. [1]: https://waplusmods.com/
alexkitt6
alexkitt6 posted this 25 July 2025
Great discussion! Just as precision matters when exporting files in Themler, Central Valley Dentistry values accuracy and advanced techniques for delivering exceptional dental care. Visit cvdentistryllc.com to discover how we create healthy, confident smiles with modern technology.
Great discussion! Just as precision matters when exporting files in Themler, [Central Valley Dentistry][1] values accuracy and advanced techniques for delivering exceptional dental care. Visit cvdentistryllc.com to discover how we create healthy, confident smiles with modern technology. [1]: https://cvdentistryllc.com/
davidlara8240
davidlara8240 posted this 26 July 2025
Very helpful thread — locating export files in WordPress via Themler can be tricky without guidance like this. After hours of theme work, I usually relax with some mobile gaming. If you enjoy racing games, definitely try GRID Autosport APK — it brings a console-quality experience right to your phone!
Very helpful thread — locating export files in WordPress via Themler can be tricky without guidance like this. After hours of theme work, I usually relax with some mobile gaming. If you enjoy racing games, definitely try [GRID Autosport APK][1] — it brings a console-quality experience right to your phone! [1]: https://9mod.cc/grid-autosport/
davidlara8240
davidlara8240 posted this 29 July 2025
Thanks for the helpful info about Themler and WordPress export paths—super useful for theme customization! Speaking of customization, if you’re into tweaking your apps for a better experience, check out whassap plus. It offers advanced features and interface controls that go way beyond the standard messaging app.
Thanks for the helpful info about Themler and WordPress export paths—super useful for theme customization! Speaking of customization, if you’re into tweaking your apps for a better experience, check out [whassap plus][1]. It offers advanced features and interface controls that go way beyond the standard messaging app. [1]: https://wapplusapk.com/
Abbas Khan
Abbas Khan posted this 31 July 2025
Panda Express Chow Mein is a beloved dish from the popular American Chinese restaurant chain, Panda Express. This savory stir-fried noodle dish features a delightful combination of crunchy cabbage, celery slices, and sliced onions, all tossed together with a flavorful sauce. Originating from the United States, it has become a favorite for its simplicity and delicious taste.
Learn that what is panda express chow mein.
Panda Express Chow Mein is a beloved dish from the popular American Chinese restaurant chain, Panda Express. This savory stir-fried noodle dish features a delightful combination of crunchy cabbage, celery slices, and sliced onions, all tossed together with a flavorful sauce. Originating from the United States, it has become a favorite for its simplicity and delicious taste. Learn that **[what is panda express chow mein][1]**. [1]: https://dimsimlim.com/panda-express-chow-mien/
Amandaa
Amandaa posted this 01 August 2025
When you export changes from Themler, the zip file is typically saved to your default download location on your computer, such as the "crossy road" folder. If you're using a browser, you can check your browser's settings to see where files are downloaded by default.
When you export changes from Themler, the zip file is typically saved to your default download location on your computer, such as the "[crossy road](https://crossyroad-online.github.io/)" folder. If you're using a browser, you can check your browser's settings to see where files are downloaded by default.
davidlara8240
davidlara8240 posted this 07 August 2025
Helpful thread! Just like locating exported files in WordPress can be tricky, many users also face trouble navigating government portals. If you're trying to verify your status, the 8171 check online CNIC login portal
Helpful thread! Just like locating exported files in WordPress can be tricky, many users also face trouble navigating government portals. If you're trying to verify your status, the [8171 check online CNIC][1] login portal [1]: https://benazirincomesupportprogramme.pk/%D8%A7%D8%AD%D8%B3%D8%A7%D8%B3-8171-%D9%BE%DB%8C%D8%B3%DB%92-%DA%86%DB%8C%DA%A9-%DA%A9%D8%B1%D9%86%DB%92-%DA%A9%D8%A7-%D8%B7%D8%B1%DB%8C%D9%82%DB%81/
informationofworld2
informationofworld2 posted this 09 August 2025
Chick-fil-A serves a range https://chick-filaa-menu.com/ of customer favorites at affordable prices. The Chicken Sandwich combo is usually priced at around $5.85, and you can get an 8-piece Nuggets combo for roughly the same amount. If you're in the mood for dessert, a large hand-spun milkshake will set you back about $3.09.
ketog58381
ketog58381 posted this 21 August 2025
When you export a theme using Themler from a WordPress installation, the exported file is usually saved as a .zip archive inside the WordPress theme directory, typically located at:
/wp-content/uploads/themler/exports/
You can then download this file and install it on another WordPress site or use it for backup. If you don’t see it there, check your hosting file manager or use FTP to locate the export folder. Just like when using tools such as vnrom bypass to access hidden system files, having the correct path in WordPress ensures you can properly manage your exported Themler themes.
Would you like me to also guide you on how to re-import that Themler export into another WordPress installation?
When you export a theme using Themler from a WordPress installation, the exported file is usually saved as a .zip archive inside the WordPress theme directory, typically located at: /wp-content/uploads/themler/exports/ You can then download this file and install it on another WordPress site or use it for backup. If you don’t see it there, check your hosting file manager or use FTP to locate the export folder. Just like when using tools such as [vnrom bypass][1] to access hidden system files, having the correct path in WordPress ensures you can properly manage your exported Themler themes. Would you like me to also guide you on how to re-import that Themler export into another WordPress installation? [1]: https://frpbypassapp.com/vnrom-bypass-apk/
gbappsdl.com.pk
gbappsdl.com.pk posted this 26 August 2025
GB WhatsApp Download is the modified version of WhatsApp, developed by third-party developers. It offers more advanced features like hiding blue ticks, hiding view status, freezing last seen, sharing large files, downloading status, and many more remarkable features with customizations.
[GB WhatsApp Download][1] is the modified version of WhatsApp, developed by third-party developers. It offers more advanced features like hiding blue ticks, hiding view status, freezing last seen, sharing large files, downloading status, and many more remarkable features with customizations. [1]: https://gbappsdl.com.pk/download/
ridewithustoday.in
ridewithustoday.in posted this 31 August 2025
On this Thanksgiving Day 2025, I’m thankful for friends like you. May your holiday be as sweet as pumpkin pie and as bright as autumn leaves.
On this [Thanksgiving Day 2025][1], I’m thankful for friends like you. May your holiday be as sweet as pumpkin pie and as bright as autumn leaves. [1]: https://thanksgivingday2025.com/
Abbas Khan
Abbas Khan posted this 01 September 2025
Enhances the buttery coconut taste and balances sweetness. Eggs: Bind the batter, add richness, and help develop that golden top crust. Whole milk: Softens the dense and chewy texture, keeping it moist and beginner-friendly. Coconut milk: Adds richness and that signature coconut-y dessert flavor. Butter Mochi, melted: Infuses the batter with nutty, buttery goodness and creates crisp edges. Vanilla extract: Adds warmth and depth, rounding out this comfort food dessert beautifully.
Enhances the buttery coconut taste and balances sweetness. Eggs: Bind the batter, add richness, and help develop that golden top crust. Whole milk: Softens the dense and chewy texture, keeping it moist and beginner-friendly. Coconut milk: Adds richness and that signature coconut-y dessert flavor. **[Butter Mochi][1]**, melted: Infuses the batter with nutty, buttery goodness and creates crisp edges. Vanilla extract: Adds warmth and depth, rounding out this comfort food dessert beautifully. [1]: https://zhangcatherine.com/butter-mochi/
inazeer.mehar
inazeer.mehar posted this 02 September 2025
This app is a game changer for photo editing. With PicsArt mod apk, you don’t have to worry about restrictions—it truly encourages you to experiment and improve your skills.
This app is a game changer for photo editing. With [PicsArt mod apk][1], you don’t have to worry about restrictions—it truly encourages you to experiment and improve your skills. [1]: https://pixsartpro.pro
inazeer.mehar
In the arena of streaming apps, MagisTV holds a unique position as it offers a large collection of movies, TV series and live channels in HD quality.
In the arena of streaming apps, [MagisTV][1] holds a unique position as it offers a large collection of movies, TV series and live channels in HD quality. [1]: https://magistvdl.com
inazeer.mehar
inazeer.mehar posted this 04 September 2025
I recommend trying the Snapchat cracked APK if you want a completely free experience with premium features. It’s lightweight, runs smoothly even on older devices, and doesn’t lag when using filters or lenses. This version is a must-have for power users.
I recommend trying the [Snapchat cracked APK][1] if you want a completely free experience with premium features. It’s lightweight, runs smoothly even on older devices, and doesn’t lag when using filters or lenses. This version is a must-have for power users. [1]: https://snaplusapk.com
