Hi i want to use the same hover effect like in this site : https://y.co/yacht-charter
When i hover some block with boat/yacht, they move/zoom in, how to do exactly the same effects?
I believe there is one (shop) template in Themler cloud with section of images and effect like this. Study code and see how it is done. I am not sure, i believe I have seen one like this.
Dont know if it was Prestashop, Magento or WooCommerce, check them all.
I believe there is one (shop) template in Themler cloud with section of images and effect like this. Study code and see how it is done. I am not sure, i believe I have seen one like this. Dont know if it was Prestashop, Magento or WooCommerce, check them all.Hi, thanks for fast answer, can you send me a link or keywords how to find this sections ?
Hi, thanks for fast answer, can you send me a link or keywords how to find this sections ?I forgot it, was long time ago. It was one shop CMS theme with 3 images right above footer. Custom sections done by Themler developers. There you can study code and settings.
I forgot it, was long time ago. It was one shop CMS theme with 3 images right above footer. Custom sections done by Themler developers. There you can study code and settings.No, I was wrong. it was different hover effect.
http://templates.themler.com/Themes/Preview?id=1905104
Will use oportunity to say to developers many demo Themes have wrong links now and doesnt work. Majority of Prestashop/Magento demo themes.
No, I was wrong. it was different hover effect. http://templates.themler.com/Themes/Preview?id=1905104 Will use oportunity to say to developers many demo Themes have wrong links now and doesnt work. Majority of Prestashop/Magento demo themes.But, do it manually. Not so big deal, takes 30 seconds.
.your-class-holding-image img
border: none;
margin: 0;
display:block;
/* Webkit for Chrome and Safari */
-webkit-transition-duration: 500ms;
-webkit-transition-timing-function: ease-out;
/* Webkit for Mozila Firefox */
-moz-transform: scale(1, 1);
-moz-transition-duration: 500ms;
-moz-transition-timing-function: ease-out;
/* Webkit for IE( Version: 11, 10 ) */
-ms-transform: scale(1, 1);
-ms-transition-duration: 500ms;
-ms-transition-timing-function: ease-out;
.your-class-holding-image img:hover {
-webkit-transform: scale(1.4, 1.4); // This is the enlarged size scale of the image.
-moz-transform: scale(1.4, 1.4);
-ms-transform: scale(1.40, 1.40);
border: none;
margin: 0;
display:block;
