now it works not correctly.
1. i have Theme A
2. i change it to B (without saving)
3. i press 'Save theme as' button to Theme C
we receive situation where C=A, not B.
more correctly C=B...
sorry my English
1. i have Theme A
sorry my English
I'm not sure that I understand the sequence properly but B project is not saved one. So in fact it is A project. If A project is saved as C, then C is the same to A.
I do not see any problem here.
in photoshop (for example) AND other programs
SaveAs function acts as
Save.... As.
So it first do save, then do it with new name
(sorry my english)
in fact to "Save As" i must press "Save" then press "saveAs"
in photoshop (for example) AND other programs SaveAs function acts as Save.... As. So it first do save, then do it with new name (sorry my english) in fact to "Save As" i must press "Save" then press "saveAs"Last edited 17 November 2016 by maf_angel
Themler works differently a bit as templates are a different element. So you need to press Apply or Save button first. The Save As function saves the current instance only not to override the original template.
Таким образом это работает неожиданно для людей и отличается от всех-всех программ, которые работают иначе.
Таким образом это работает неожиданно для людей и отличается от всех-всех программ, которые работают иначе.Спасибо, что обратились к нам. Мы внесем ваше пожелание в наш виш лист.
