Joomla HTML element and php
uwe.pfeiffe
uwe.pfeiffe posted this 15 November 2016
in Themler (Joomla) I inserted a HTML element and edit the text in the ribbon with the following content :
<?php echo ("hallo");?>
Wher I reopen the edit field I see that's it's changed to
<!--?php echo ("Hallo"); ?-->
The word Hallo is not shown.
Can I insert PHP Code within the HTML element ?? And how to do that ??
Best regards
Uwe Pfeiffer
Hello, in Themler (Joomla) I inserted a HTML element and edit the text in the ribbon with the following content : &lt;?php echo (&quot;hallo&quot;);?&gt; Wher I reopen the edit field I see that's it's changed to &lt;!--?php echo (&quot;Hallo&quot;); ?--&gt; The word Hallo is not shown. Can I insert PHP Code within the HTML element ?? And how to do that ?? Best regards Uwe Pfeiffer
Support Team posted this 16 November 2016
Use the CMS Code control to insert the PHP code.
Hi, Use the CMS Code control to insert the PHP code. Sincerely, Hella
uwe.pfeiffe
uwe.pfeiffe posted this 17 November 2016
Thanks you ..
but as I see CMS Code can only be placed on the top of an article ??
All other positions in Columns are not possible.. ?
When I move my mouse ith CMS element all columns are no longer visible..
Best regards
Uwe Pfeiffer
Thanks you .. but as I see CMS Code can only be placed on the top of an article ?? All other positions in Columns are not possible.. ? When I move my mouse ith CMS element all columns are no longer visible.. Best regards Uwe Pfeiffer
Support Team posted this 17 November 2016
You can insert the CMS Code inside the Column control. Please provide your theme and explain where exactly you need to add the CMS Code control.
Hi, You can insert the CMS Code inside the Column control. Please provide your theme and explain where exactly you need to add the CMS Code control. Sincerely, Hella
