Joomla blog columns
heirogn
heirogn posted this 18 November 2016
In Themler I can choose number of columns for different devices in the layout options. As far as I can see there is a problem if I want 1 column for tablets and phones and use Joomla settings for laptops and desktops. It would be better if it was possible to set number of columns in Themler for the desired device and down in stead of for the desired device and up as it is in current version.
In Themler I can choose number of columns for different devices in the layout options. As far as I can see there is a problem if I want 1 column for tablets and phones and use Joomla settings for laptops and desktops. It would be better if it was possible to set number of columns in Themler for the desired device and **down** in stead of for the desired device and **up** as it is in current version.
Support Team posted this 21 November 2016
That is the bootstrap default behavior and we can not change it.
Hi, That is the bootstrap default behavior and we can not change it. Sincerely, Hella
heirogn
heirogn posted this 21 November 2016
Doesn't Bootstrap as default use 1 column on tablets and phones even if there are two columns on laptop and desktop?
If I leave the settings empty in Themler and use the joomla settings there are still two columns on tablets and phones.
Doesn't Bootstrap as default use 1 column on tablets and phones even if there are two columns on laptop and desktop? If I leave the settings empty in Themler and use the joomla settings there are still two columns on tablets and phones.
Support Team posted this 22 November 2016
You cannot use combination of joomla and Themler settings. You can use either Themler or joomla settings. The joomla settings used when no columns specified in Themler (when fields for all resp modes are empty).
If you need to columns in Desktop and Laptop and one column in Tablet and Phone you should use the following settings in Themler:
Hi, You cannot use combination of joomla and Themler settings. You can use either Themler or joomla settings. The joomla settings used when no columns specified in Themler (when fields for **all** resp modes are empty). If you need to columns in Desktop and Laptop and one column in Tablet and Phone you should use the following settings in Themler: !columns-resp.png! Thank you, Olivia
heirogn
heirogn posted this 22 November 2016
I would like to use Joomla settings and left the fields under posts/ layout empty for all modes. Then I have two columns on phone and tablet with two columns blog setting in joomla. Usually two columns blogs are changing to one column on phones and tablets in Joomla, like it also does when I am testing my site with Protostar template. I have not inserted any extra columns in Themler, so I don't see the columns menu in your image. If I should, could you please explain how I can get to it.
I would like to use Joomla settings and left the fields under **posts/ layout** empty for all modes. Then I have two columns on phone and tablet with two columns blog setting in joomla. Usually two columns blogs are changing to one column on phones and tablets in Joomla, like it also does when I am testing my site with Protostar template. I have not inserted any extra columns in Themler, so I don't see the columns menu in your image. If I should, could you please explain how I can get to it.
Support Team posted this 23 November 2016
you may specify necessary number of columns in different screen sizes in Themler theme.
For example if column width is set to
-100% it means 1 column layout
-50% it means 2 columns layout
-33% it means 3 columns layout
etc.
Hello, you may specify necessary number of columns in different screen sizes in Themler theme. For example if column width is set to -100% it means 1 column layout -50% it means 2 columns layout -33% it means 3 columns layout etc. regards, Aileen
