Homepage, frontpage layout.
- Option to make it possible to insert custom Themler template inside Themler template.
- We could name them as our categories and Themler would beat all those commercial fancy WordPress themes with very special Home layouts.
It could be done with widgets positions and widgets for Posts listings. But then not possible to use very good Bootstrap and listing in multiple columns. Not without heavy manual tweaking. And styling for responsive is hedache.
- Option can be very minimalistic.
- We are editing Home template (or some custom Home template)
- We insert one row with one column (or some other block)
- Then we insert CMS Content Sidebar (not widget position)
- We dont need header, menu, other sidebars, footer, etc...
Themler would need to give option to handle this CMS Content Sidebar as separate custom template, and give us option to name it, filename.
Look at Recipology theme and homepage. Imagine all those page wide blocks as separate WP loops, pulled from separate PHP archive templates. And not as now HTML blocks, or widgets display.
Rest can we do manually. It is easy to limit number of posts per loop with simple snippets.
It is all about the nice Themler part, Bootstrap. All this can be done with widgets, but then forget about Themler Bootstrap. Or Themler editing at all.
Homepage, frontpage layout. - Option to make it possible to insert custom Themler template inside Themler template. - We could name them as our categories and Themler would beat all those commercial fancy WordPress themes with very special Home layouts. It could be done with widgets positions and widgets for Posts listings. But then not possible to use very good Bootstrap and listing in multiple columns. Not without heavy manual tweaking. And styling for responsive is hedache. - Option can be very minimalistic. - We are editing Home template (or some custom Home template) - We insert one row with one column (or some other block) - Then we insert CMS Content Sidebar (not widget position) - We dont need header, menu, other sidebars, footer, etc... Themler would need to give option to handle this CMS Content Sidebar as separate custom template, and give us option to name it, filename. Look at Recipology theme and homepage. Imagine all those page wide blocks as separate WP loops, pulled from separate PHP archive templates. And not as now HTML blocks, or widgets display. Rest can we do manually. It is easy to limit number of posts per loop with simple snippets. It is all about the nice Themler part, Bootstrap. All this can be done with widgets, but then forget about Themler Bootstrap. Or Themler editing at all.
