add new font to themler
eiman.m.alotaibi
eiman.m.alotaibi posted this 23 November 2016
how can i add new font which is not in the font family that in the themler ? and is it possible?
11 Comments
Support Team posted this 23 November 2016
Themler uses system fonts (installed in your system) and google fonts. It does not provide own fonts library.
If you want to use custom font I suggest that you try the following solution:
1. install it in your system and use it as system font. But in this case the font will not be visible to your site visitors who do not have it installed. So you need to link it to the project.
2. For this you need to upload font file (ttf, woff, etc) to your webserver and link to the theme using @font-face css rule.
http://www.w3schools.com/cssref/css3_pr_font-face_rule.asp
The custom css can be added to he Themler Home tab >> Settings >> Additional CSS.
Hi, Themler uses system fonts (installed in your system) and google fonts. It does not provide own fonts library. If you want to use custom font I suggest that you try the following solution: 1. install it in your system and use it as system font. But in this case the font will not be visible to your site visitors who do not have it installed. So you need to link it to the project. 2. For this you need to upload font file (ttf, woff, etc) to your webserver and link to the theme using `@font-face` css rule. http://www.w3schools.com/cssref/css3_pr_font-face_rule.asp The custom css can be added to he Themler Home tab >> Settings >> Additional CSS. Thank you, Olivia
plexforce
plexforce posted this 22 January 2018
How can i do this?
i have this font:
https://www.dafont.com/search.php?q=kg+somebody
Download it and installed on Windows.
Then uploaded to the root folder of WWW.
And in the Settings of Themler:
Additonal CSS:
@font-face {
font-family: KG-somebody;
src: url(https://www.domeinname.com/KGSomebodyThatIUsedToKnow.ttf);
I dont see the font appear into the text fonts.
Hi, How can i do this? i have this font: https://www.dafont.com/search.php?q=kg+somebody Download it and installed on Windows. Then uploaded to the root folder of WWW. And in the Settings of Themler: Additonal CSS: @font-face { font-family: KG-somebody; src: url(https://www.domeinname.com/KGSomebodyThatIUsedToKnow.ttf); } I dont see the font appear into the text fonts.
Support Team posted this 22 January 2018
You need to apply the font to some element. For example:
h1
It will work of the link to the font is correct, if browser can display ерша format of font and the font was not blocked by CORS policy.
Hi, You need to apply the font to some element. For example: `h1 { font-family: KG-somebody; }` It will work of the link to the font is correct, if browser can display ерша format of font and the font was not blocked by CORS policy. Thank you, Olivia
plexforce
plexforce posted this 23 January 2018
Hi Olivia,
Thanks for your quick reply.
But im sorry, but I cant make this work :(
I have add this into the Additional CSS:
@font-face {
font-family: 'KG-somebody';
src: local('KGSomebodyThatIUsedToKnow'), url(https://www.domeinname.com/KGSomebodyThatIUsedToKnow.ttf) format('truetype');
h1
Then I add a text element, with H1. But it shows the chosen font of Themler, not the CSS one.
Hi Olivia, Thanks for your quick reply. But im sorry, but I cant make this work :( I have add this into the Additional CSS: @font-face { font-family: 'KG-somebody'; src: local('KGSomebodyThatIUsedToKnow'), url(https://www.domeinname.com/KGSomebodyThatIUsedToKnow.ttf) format('truetype'); } h1 { font-family: KG-somebody; } Then I add a text element, with H1. But it shows the chosen font of Themler, not the CSS one.
Support Team posted this 23 January 2018
Do you mean that you're using exactly the code you provided?
The link to the font is not real:
Looks like this is dummy code. You need the real link to the existing font.
Hi, Do you mean that you're using exactly the code you provided? The link to the font is not real: https://www.domeinname.com/KGSomebodyThatIUsedToKnow.ttf Looks like this is dummy code. You need the real link to the existing font. Thank you, Olivia
plexforce
Yes ofcourse :) haha, I just put a dummy, the real link works. (when i click, it download the font.)
plexforce,
Have you managed to solve the issue with custom fonts?
If not please create a new private topic and provide us with the code you're using with real links and a link to the website that demonstrates the issue.
plexforce, Have you managed to solve the issue with custom fonts? If not please create a new private topic and provide us with the code you're using with real links and a link to the website that demonstrates the issue. Thank you, Olivia
chagall57
chagall57 posted this 01 August 2019
i have get this code (its ok on pc but i cant see it on android phone)
what is wrong in this code for see it in my phone ?
@font-face {
rc: url('HTTPS//.....................');
font-family: 'market_decoregular';
src: url('market_deco-webfont.eot');
src: url('market_deco-webfont.eot?#iefix') format('embedded-opentype'),
url('market_deco-webfont.woff2') format('woff2'),
url('market_deco-webfont.woff') format('woff'),
url('market_deco-webfont.ttf') format('truetype'),
url('market_deco-webfont.svg#market_decoregular') format('svg');
font-weight: normal;
font-style: normal;
i have get this code (its ok on pc but i cant see it on android phone) what is wrong in this code for see it in my phone ? @font-face { rc: url('HTTPS//.....................'); font-family: 'market_decoregular'; src: url('market_deco-webfont.eot'); src: url('market_deco-webfont.eot?#iefix') format('embedded-opentype'), url('market_deco-webfont.woff2') format('woff2'), url('market_deco-webfont.woff') format('woff'), url('market_deco-webfont.ttf') format('truetype'), url('market_deco-webfont.svg#market_decoregular') format('svg'); font-weight: normal; font-style: normal; }
Support Team posted this 01 August 2019
The second line is definitely wrong, maybe a typo.
Then, it is recommended to use absolute URLs for font sources.
Hello, The second line is definitely wrong, maybe a typo. Then, it is recommended to use absolute URLs for font sources. Sincerely, Nettie
alexarafatonline
alexarafatonline posted this 28 December 2025
Yes, it’s usually possible, and I’ve been there myself. When I was customizing a theme and couldn’t find the right font, I realized how beautiful fonts have revolutionized how people express themselves visually in the digital world—it really is about presentation, not just content. Most themes let you add custom fonts by uploading font files or linking them through CSS, even if they’re not in the default font family. While experimenting, I explored typography resources like letrabonitas.com for inspiration and style ideas. Once I added a custom font, the whole site felt more personal and visually engaging.
Yes, it’s usually possible, and I’ve been there myself. When I was customizing a theme and couldn’t find the right font, I realized how beautiful fonts have revolutionized how people express themselves visually in the digital world—it really is about presentation, not just content. Most themes let you add custom fonts by uploading font files or linking them through CSS, even if they’re not in the default font family. While experimenting, I explored typography resources like [letrabonitas.com][1] for inspiration and style ideas. Once I added a custom font, the whole site felt more personal and visually engaging. [1]: https://letrabonitas.com/
alexarafatonline
alexarafatonline posted this 09 February 2026
Adding a new font that’s not in your theme’s default font family can be tricky but usually possible by uploading custom fonts via your site’s CSS or using plugins. It depends on the platform and theme flexibility. It reminds me of how everyone loves Instagram but struggles with plain default fonts—that’s why I use igfontsgen, an Ig Font Generator that creates cool, unique font styles you can copy-paste anywhere without needing to install fonts. It’s a quick and free way to make your text stand out, especially if your theme limits font choices.
Adding a new font that’s not in your theme’s default font family can be tricky but usually possible by uploading custom fonts via your site’s CSS or using plugins. It depends on the platform and theme flexibility. It reminds me of how everyone loves Instagram but struggles with plain default fonts—that’s why I use [igfontsgen][1], an Ig Font Generator that creates cool, unique font styles you can copy-paste anywhere without needing to install fonts. It’s a quick and free way to make your text stand out, especially if your theme limits font choices. [1]: https://igfontsgen.com/
