counter
dmintermedia
dmintermedia posted this 23 November 2016
whether themler is possible to insert the counter of visits to the site?
zailstalowałem counter Visitors Counter but after activating the page disappears and appears the message: 1146 - Table 'wpacura_jos1. # __ vvisitcounter' does not exist SQL = SELECT count (*) AS records, MAX (id) AS FROM max #__vvisitcounter
whether themler is possible to insert the counter of visits to the site? zailstalowałem counter Visitors Counter but after activating the page disappears and appears the message: 1146 - Table 'wpacura_jos1. # __ vvisitcounter' does not exist SQL = SELECT count (*) AS records, MAX (id) AS FROM max #__vvisitcounter
12 Comments
shopmods
shopmods posted this 23 November 2016
This has nothing to do with Themler.
You sure it should say 'vvisitcounter' and not 'visitcounter' ?
This has nothing to do with Themler. You sure it should say 'vvisitcounter' and not 'visitcounter' ?
dmintermedia
visitcounter
I worked it out differently, I installed a standard module joomla statistics
only the text is not equal to each other, see the screenshot
website:http://www.dmintermedia.h2g.pl/portal/
visitcounter I worked it out differently, I installed a standard module joomla statistics only the text is not equal to each other, see the screenshot website:http://www.dmintermedia.h2g.pl/portal/
Support Team posted this 24 November 2016
The problem is in the default styles for such elements. Please add the following code under the Home >> Settings >> Additional CSS:
dl.stats-module dd
padding: 0.3em 0.3em 0 0;
Hi, The problem is in the default styles for such elements. Please add the following code under the Home >> Settings >> Additional CSS: dl.stats-module dd { padding: 0.3em 0.3em 0 0; } Sincerely, Hella
dmintermedia
dmintermedia posted this 28 November 2016
Unfortunately, it did not help in the distribution of meter reads articles meant only that the text is larger and thick Please further ideas
Support Team posted this 29 November 2016
I see only one line with one number and my code works fine with it. Please provide a direct link to the page where there are 3 lines with the counters so we could review the code.
Hi, I see only one line with one number and my code works fine with it. Please provide a direct link to the page where there are 3 lines with the counters so we could review the code. Sincerely, Hella
dmintermedia
dmintermedia posted this 29 November 2016
website on which work is still the same:
http://www.siatkibrzesko.pl/
website on which work is still the same: http://www.siatkibrzesko.pl/
Support Team posted this 30 November 2016
It looks just fine when I add the code:
dl.stats-module dt
padding:0px!important
Hela
Hi, It looks just fine when I add the code: dl.stats-module dt { padding:0px!important } Sincerely, Hela
dmintermedia
dmintermedia posted this 30 November 2016
cool! was it thanks, greetings
Support Team posted this 02 December 2016
you're welcome!
Let us know if you have additional questions.
Hello, you're welcome! Let us know if you have additional questions. regards, Aileen
benstokes1906
benstokes1906 posted this 10 January 2026
For simple counting needs, using an online counting tool
can be really practical. It helps keep track of numbers quickly without writing things down and works well for tasks like attendance, score keeping, or basic tracking.
For simple counting needs, using an online [counting tool][1] can be really practical. It helps keep track of numbers quickly without writing things down and works well for tasks like attendance, score keeping, or basic tracking. [1]: https://thetallycounter.com/
studwork1742
studwork1742 posted this 18 January 2026
Olá, tive uma discussão sobre segurança online e comecei a pesquisar melhor. Buscava um casino que transmitisse mais confiança visual. No winaura senti que tudo é apresentado de forma simples. As promoções para Portugal incluem bônus de boas-vindas e algumas ofertas frequentes, explicadas sem confusão e com regras acessíveis para quem não é especialista. Gostei porque passa mais calma.
Olá, tive uma discussão sobre segurança online e comecei a pesquisar melhor. Buscava um casino que transmitisse mais confiança visual. No [winaura][1] senti que tudo é apresentado de forma simples. As promoções para Portugal incluem bônus de boas-vindas e algumas ofertas frequentes, explicadas sem confusão e com regras acessíveis para quem não é especialista. Gostei porque passa mais calma. [1]: http://win-aura.pt/
chinahousehold
chinahousehold posted this 20 January 2026
https://all4webs.com/bothbest/bambooveneerforlu.htm?35503=37018
https://graphcommons.com/graphs/fdb3a1f2-a7d3-40e2-8bd2-ddd535483ef5
https://graphcommons.com/graphs/cdff798b-7056-4b55-b73f-cffae5942768
https://graphcommons.com/graphs/4e41f3a9-0992-4717-a5be-9b06b7b948c3
http://bbs.medicalforum.cn/home.php?mod=space&uid=2021016
https://www.theconsumersfeedback.com/guestpost/bamboo-veneer-modern-interior-trends-you-need-to-see
https://bothbest.amebaownd.com/posts/58432779
https://www.xcspa.com/subfloor-preparation-tips-before-installing-bamboo-flooring/
http://scenarch.com/scenarios/4090
https://whatoplay.com/review/45389/
https://sngine.fr/blogs/24257/Safe-and-Sustainable-Why-FSC-Certified-Bamboo-Matters
https://bothbest.weebly.com/blog/comparing-bamboo-plywood-grades-what-consumers-should-look-for
https://japaneseclass.jp/notes/open/109333
https://lalinguanostra.com/blogs/47772/Why-Premium-Density-Bamboo-Performs-Better
https://home.gamer.com.tw/artwork.php?sn=6273500
https://codoc.jp/sites/bothbest/entries/AYwrCgY1NA
https://bothbest.gitbook.io/bothbest-docs/documentation/how-high-efficiency-modules-improve-returns-for-commercial-projects
https://www.123articleonline.com/articles/1512164/outdoor-bamboo-uv-resistance-weathering-and-color-stability
https://bambooflooring.alboompro.com/post/the-rise-of-ultra-thin-silicon-more-power-less-material
https://roughstuffmedia.activeboard.com/t72449905/how-advanced-robotics-improve-solar-module-reliability/
https://kumu.io/bothbest/why-ultra-thin-wafers-offer-better-performance-to-cost-ratios
http://poster.4teachers.org/worksheet/view.php?id=195297
https://ameblo.jp/japanbamboo/entry-12953939567.html
https://hssolar.tawk.help/article/why-automated-production-lines-produce-more-consistent-quality
https://www.hssolar.cn/news-41.html
https://www.theconsumersfeedback.com/guestpost/boosting-solar-output-with-low-lid-and-pid-resistant-modules
https://kisanlink.com/forums/discussion/general-discussion/how-superior-temperature-coefficients-boost-summer-energy-yield-1
https://www.2biz.ro/600w-topcon-solar-panel-pf
https://all4webs.com/bothbest/bambooveneerforlu.htm?35503=37018 https://graphcommons.com/graphs/fdb3a1f2-a7d3-40e2-8bd2-ddd535483ef5 https://graphcommons.com/graphs/cdff798b-7056-4b55-b73f-cffae5942768 https://graphcommons.com/graphs/4e41f3a9-0992-4717-a5be-9b06b7b948c3 http://bbs.medicalforum.cn/home.php?mod=space&uid=2021016 https://www.theconsumersfeedback.com/guestpost/bamboo-veneer-modern-interior-trends-you-need-to-see https://bothbest.amebaownd.com/posts/58432779 https://www.xcspa.com/subfloor-preparation-tips-before-installing-bamboo-flooring/ http://scenarch.com/scenarios/4090 https://whatoplay.com/review/45389/ https://sngine.fr/blogs/24257/Safe-and-Sustainable-Why-FSC-Certified-Bamboo-Matters https://bothbest.weebly.com/blog/comparing-bamboo-plywood-grades-what-consumers-should-look-for https://japaneseclass.jp/notes/open/109333 https://lalinguanostra.com/blogs/47772/Why-Premium-Density-Bamboo-Performs-Better https://home.gamer.com.tw/artwork.php?sn=6273500 https://codoc.jp/sites/bothbest/entries/AYwrCgY1NA https://bothbest.gitbook.io/bothbest-docs/documentation/how-high-efficiency-modules-improve-returns-for-commercial-projects https://www.123articleonline.com/articles/1512164/outdoor-bamboo-uv-resistance-weathering-and-color-stability https://bambooflooring.alboompro.com/post/the-rise-of-ultra-thin-silicon-more-power-less-material https://roughstuffmedia.activeboard.com/t72449905/how-advanced-robotics-improve-solar-module-reliability/ https://kumu.io/bothbest/why-ultra-thin-wafers-offer-better-performance-to-cost-ratios http://poster.4teachers.org/worksheet/view.php?id=195297 https://ameblo.jp/japanbamboo/entry-12953939567.html https://hssolar.tawk.help/article/why-automated-production-lines-produce-more-consistent-quality https://www.hssolar.cn/news-41.html https://www.theconsumersfeedback.com/guestpost/boosting-solar-output-with-low-lid-and-pid-resistant-modules https://kisanlink.com/forums/discussion/general-discussion/how-superior-temperature-coefficients-boost-summer-energy-yield-1 https://www.2biz.ro/600w-topcon-solar-panel-pf
