How do I publish my webpage designed in Themler/Wordpress to my FTP server
How do I publish my webpage designed in Themler/Wordpress to my FTP serverHello,
Just export the theme from File tab >> Export as ZIP and install the theme in Wordpress on your server:
http://answers.themler.com/articles/3624/how-to-install-wordpress-theme
Let us know if any issues appear in process.
To publish your webpage designed in Themler/WordPress to your FTP server, first export your design as a ZIP file. Connect to your FTP server using an FTP client like FileZilla, then upload and unzip the file in the desired directory. Ensure all files are in the correct folders and configure your WordPress settings to match the server environment. Finally, test your site to ensure it functions correctly. For a seamless transition, consider seeking assistance from a professional web design company.
To publish your webpage designed in Themler/WordPress to your FTP server, first export your design as a ZIP file. Connect to your FTP server using an FTP client like FileZilla, then upload and unzip the file in the desired directory. Ensure all files are in the correct folders and configure your WordPress settings to match the server environment. Finally, test your site to ensure it functions correctly. For a seamless transition, consider seeking assistance from a professional **[web design company][1]**. [1]: https://dubaimonsters.com/
