How to draw themler mark on footer
Edson Cruz Webdesing
Edson Cruz Webdesing posted this 29 November 2016
How to remove themler mark on footer
How to remove themler mark on footer Thank you
Support Team posted this 30 November 2016
This control can be hidden: Home tab >> Settings >> disable "Show Backlinks" option.
Hello, This control can be hidden: Home tab >> Settings >> disable "Show Backlinks" option. Sincerely, Nettie, BillionDigital Team
Edson Cruz Webdesing posted this 30 November 2016
Good Morning
I would like to know how do I create a menu in themler aided by wordpress as attached screen.
When I save the template made by me, I export the files by FTP to my hosting server in my domain, "www.divulgweb.com.br".
He does not appear as I created.
What should I do?
Good Morning I would like to know how do I create a menu in themler aided by wordpress as attached screen. When I save the template made by me, I export the files by FTP to my hosting server in my domain, "www.divulgweb.com.br". He does not appear as I created. What should I do?
There are two possible solution:
  1. Export theme with content from where you created it (local Themler, for example) and then import content on www.divulgweb.com.br. The content import feature exports posts, pages with images and menus.
  2. Create new menu under the WP Appearance >> Menus and put it into the appropriate locale, for example, "Primary Navigation".
Hi, There are two possible solution: 1. Export theme with content from where you created it (local Themler, for example) and then import content on www.divulgweb.com.br. The content import feature exports posts, pages with images and menus. 2. Create new menu under the WP Appearance >> Menus and put it into the appropriate locale, for example, "Primary Navigation". Thank you, Olivia
Good afternoon.
I have a fundamental question to begin to understand how to use Themler.
First Screen:
As the on-screen arrow (the first screen) shows with the wordpress logo, I understand that I can click on it and work directly on wordpress with the Themler template?
As the (second screen) shows?
On the (Third screen) I would like to know how to put the wordpress address of my site, so that I can, as I go EDITING the site, I can go directly posted to my URL address. http://www.divulgweb.com.br
How do I do that?
I can according to the (fourth screen) URL address. Edit and Post Direct to my Site.
How do I do that ?
Urgent
Good afternoon. I have a fundamental question to begin to understand how to use Themler. First Screen: As the on-screen arrow (the first screen) shows with the wordpress logo, I understand that I can click on it and work directly on wordpress with the Themler template? As the (second screen) shows? On the (Third screen) I would like to know how to put the wordpress address of my site, so that I can, as I go EDITING the site, I can go directly posted to my URL address. http://www.divulgweb.com.br How do I do that? I can according to the (fourth screen) URL address. Edit and Post Direct to my Site. How do I do that ? Thank you Urgent
Edson Cruz Webdesing posted this 01 December 2016
Thanks for the answer. Support too slow.
We work with site developments for our customers, and when we buy a program from your company "Themler" the most important thing is the speed in its support.
The above question I have already resolved.
Thanks for the answer. Support too slow. We work with site developments for our customers, and when we buy a program from your company "Themler" the most important thing is the speed in its support. The above question I have already resolved.
I need your help.
When I try to edit only one page, I save and publish the page change.
It changes on all pages.
What should I do to edit only one page of a menu.
I need your help. When I try to edit only one page, I save and publish the page change. It changes on all pages. What should I do to edit only one page of a menu. Thank you
Support Team posted this 02 December 2016
Sorry for the delay. We usually respond in 1-3 business days.
As for the last question. I assume that you have edited the blue area of the template. That is the template part that is the same for all pages using that template. To insert the controls into the content area that will be specific for each page, insert them into the green area marked as content.
Hi, Sorry for the delay. We usually respond in 1-3 business days. As for the last question. I assume that you have edited the blue area of the template. That is the template part that is the same for all pages using that template. To insert the controls into the content area that will be specific for each page, insert them into the green area marked as content. Sincerely, Hella
