Dear support,
We use themler to build wordpress themes for our customers. Up till recently no problem, but now we have a problem. For most customers we use visual composer page builder to have optimal flexibility. I think before the last up date we had no problems. What happens? We build the header and footer in themler. Further we define the fonts etc. With visual composer we build the individual pages, which are shown in the content & sidebars area in themler.
Previously we had no problems with editing in visual composer, but now if we update the page it gives an extra first row with [html] and at the end [/html]. Because it places the code in rows it does not apply the css from the theme, that build in themler. The only way to avoid this is with every page you edit to remove these codes before editing from the classic code and put them back in the classic before updating the page. We work with visual composer so that our customers can do the changes to their webiste themselves, but now it is impossible. We can not expect from them to change the classic page code before editing and just also just before updating. Do you know what happened that it does not work any longer?
Dear support, We use themler to build wordpress themes for our customers. Up till recently no problem, but now we have a problem. For most customers we use visual composer page builder to have optimal flexibility. I think before the last up date we had no problems. What happens? We build the header and footer in themler. Further we define the fonts etc. With visual composer we build the individual pages, which are shown in the content & sidebars area in themler. Previously we had no problems with editing in visual composer, but now if we update the page it gives an extra first row with [html] and at the end [/html]. Because it places the code in rows it does not apply the css from the theme, that build in themler. The only way to avoid this is with every page you edit to remove these codes before editing from the classic code and put them back in the classic before updating the page. We work with visual composer so that our customers can do the changes to their webiste themselves, but now it is impossible. We can not expect from them to change the classic page code before editing and just also just before updating. Do you know what happened that it does not work any longer?
