Does Themler have Flexbox capabilities?
rajsidhux
rajsidhux posted this 01 December 2016
I was wondering if flexbox was built into Themler or not.
Does anyone know if it does?
I was wondering if flexbox was built into Themler or not. Does anyone know if it does?
6 Comments
Support Team posted this 01 December 2016
Yes, in Themler you can use flex order option for columns and sidebars. That option can be found in the right panel (press More on some top ribbon option) for above mentioned elements.
Hi, Yes, in Themler you can use flex order option for columns and sidebars. That option can be found in the right panel (press More on some top ribbon option) for above mentioned elements. Sincerely, Hella
rajsidhux
I don't see a More option!
Is it under the ARRANGE section in the right menu panel?
> Hi, > > Yes, in Themler you can use flex order option for columns and sidebars. That option can be found in the right panel (press More on some top ribbon option) for above mentioned elements. > > Sincerely, > Hella I don't see a More option! Is it under the ARRANGE section in the right menu panel?
Yes, you can open it using the Arrange option.
Hi, Yes, you can open it using the Arrange option. Sincerely, Hella
rajsidhux
Ok, well I only see that we can assign the flex order. What about all the other options available for flexbox like:-
Align
Justify
Direction
Parent and child setting.....
Do we have access to all these settings within Themler Hella?
> Hi, > > Yes, you can open it using the Arrange option. > > Sincerely, > Hella > Ok, well I only see that we can assign the flex order. What about all the other options available for flexbox like:- Align Justify Direction Parent and child setting..... Do we have access to all these settings within Themler Hella?
rajsidhux
rajsidhux posted this 02 December 2016
Still want to know if Themler has full Flexbox controls and if so how and where to access them.
I can see where to access the flex order, thats fine. But are there any other flexbox controls we can access?
Still want to know if Themler has full Flexbox controls and if so how and where to access them. I can see where to access the flex order, thats fine. But are there any other flexbox controls we can access?
Support Team posted this 02 December 2016
No, there are no other flex options available in Themler.
Hi, No, there are no other flex options available in Themler. Sincerely, Hella
