google map scrolling in mobile devices
jeanne916
jeanne916 posted this 01 December 2016
I've seen this issue has been talked about previously but I did not find a proper updated answer.
In phone view and tablet view the google map occupies the whole screen, so when people scroll down the page the map will "lock them" in zoom mode and interrupt navegation.
What is the recommended approach to solve this? Put map size at 75% or whatever and just hope that the user "gets it" and scrolls with his finger in a little corner of his smartphone screen? If I reduce the map width % it will look too tiny too. What to do? I suppose you do not have a code to disable the "scroll to zoom" functionality WITHOUT disabling clicks and other functions?
I've seen this issue has been talked about previously but I did not find a proper updated answer. In phone view and tablet view the google map occupies the whole screen, so when people scroll down the page the map will "lock them" in zoom mode and interrupt navegation. What is the recommended approach to solve this? Put map size at 75% or whatever and just hope that the user "gets it" and scrolls with his finger in a little corner of his smartphone screen? If I reduce the map width % it will look too tiny too. What to do? I suppose you do not have a code to disable the "scroll to zoom" functionality WITHOUT disabling clicks and other functions?
Support Team posted this 02 December 2016
Yes, there is no other solution. You can search for some code to solve this or use the minimized width for the map in phone view. In any case it is default map behavior as we take the code from Google.
Hi, Yes, there is no other solution. You can search for some code to solve this or use the minimized width for the map in phone view. In any case it is default map behavior as we take the code from Google. Sincerely, Hella
jeanne916
jeanne916 posted this 02 December 2016
OK Thanks for the update. A feature that could be worth voting for.
You are welcome. The suggestion is in our wish list.
You are welcome. The suggestion is in our wish list. Sincerely, Hella
d.vangelder
d.vangelder posted this 28 January 2017
Cooperative Gesture Handling Google Maps
Maybe this could be build in Themler:
https://developers.google.com/maps/documentation/javascript/examples/interaction-cooperative
Hi, Cooperative Gesture Handling Google Maps Maybe this could be build in Themler: https://developers.google.com/maps/documentation/javascript/examples/interaction-cooperative
Stagger Lee posted this 28 January 2017
Just add mobile media queries to CSS part:
http://answers.themler.com/questions/18815/google-maps
Just add mobile media queries to CSS part: http://answers.themler.com/questions/18815/google-maps
