problem saving template as zip
aidelakreyi
aidelakreyi posted this 06 December 2016
hello ....
please solve my problem ...
i made a new design for an organisation and i finished it .. but after i export the file as zip .. its can't be installed ...
and it says ( Unable to open archive ,Unable to find install package )
hello .... please solve my problem ... i made a new design for an organisation and i finished it .. but after i export the file as zip .. its can't be installed ... and it says ( Unable to open archive ,Unable to find install package )
11 Comments
aidelakreyi
and this is my zip file
aidelakreyi
Is Solution
aidelakreyi posted this 07 December 2016
any idea ?
any idea ?
Support Team posted this 07 December 2016
The theme is not exported or downloaded completely, that is why the archive is broken. Please try temporarily disabling antivirus and firewall and also add-ons for the Chrome browser on your computer.
It can happen that antivirus or firewall are not disabled completely even if stopping them and are blocking/removing necessary files.
Please try to add the following folder to your antivirus/firewall white list:
C:\Program Files (x86)\Themler\
C:\ProgramData\Themler
and try to install and run Themler once again and export the theme.
As a temporary solution, you may copy the theme manually from the folder on your computer (the path is shown in the Theme Management screen after selecting some CMS, for example, C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla). You can zip the theme and install on your hosted website.
Hello, The theme is not exported or downloaded completely, that is why the archive is broken. Please try temporarily disabling antivirus and firewall and also add-ons for the Chrome browser on your computer. It can happen that antivirus or firewall are not disabled completely even if stopping them and are blocking/removing necessary files. Please try to add the following folder to your antivirus/firewall white list: C:\Program Files (x86)\Themler\ C:\ProgramData\Themler and try to install and run Themler once again and export the theme. As a temporary solution, you may copy the theme manually from the folder on your computer (the path is shown in the Theme Management screen after selecting some CMS, for example, `C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla`). You can zip the theme and install on your hosted website. Sincerely, Nettie, BillionDigital Team
aidelakreyi
aidelakreyi posted this 08 December 2016
Thanx for help but it still not working ...
I'm using Mac so I don't think that I have antivirus or fire wall ...
I temporary fix my problem by compressing the template inside ( themler/hd_data/templates) and it works ... ( thanks for that ) but stil my themler can't export as zip and when export is not installing as I sent you ...
I hope that you find a way to solve that in (Mac) not Windows ...
Regards...
Thanx for help but it still not working ... I'm using Mac so I don't think that I have antivirus or fire wall ... I temporary fix my problem by compressing the template inside ( themler/hd_data/templates) and it works ... ( thanks for that ) but stil my themler can't export as zip and when export is not installing as I sent you ... I hope that you find a way to solve that in (Mac) not Windows ... Regards...
Sorry for the delay,
Did you try exporting themes into a different directory (on the desktop, for example)?
You may also try exporting themes from browser directly by the following URL:
http://127.0.0.1:29958/themler_740294543/joomla/administrator
admin/admin
Themler Team
Hi, Sorry for the delay, Did you try exporting themes into a different directory (on the desktop, for example)? You may also try exporting themes from browser directly by the following URL: `http://127.0.0.1:29958/themler_740294543/joomla/administrator` admin/admin Thank you, Themler Team
Medienagentur
Medienagentur posted this 07 July 2017
Regards...
The same here. But with Win 10. ZIP File is corrupted on download. I tried to disable virenscanner and add Themler to the firewall rules but that don't work for me. Tried to change standard browser from Thunderbird to Chrom and Edge. Set Chrome back to factory settings. No change. Is there actual another solution as manual zipping the folder?
> Thanx for help but it still not working ... > I'm using Mac so I don't think that I have antivirus or fire wall ... > I temporary fix my problem by compressing the template inside ( themler/hd_data/templates) and it works ... ( thanks for that ) but stil my themler can't export as zip and when export is not installing as I sent you ... > I hope that you find a way to solve that in (Mac) not Windows ... > Regards... The same here. But with Win 10. ZIP File is corrupted on download. I tried to disable virenscanner and add Themler to the firewall rules but that don't work for me. Tried to change standard browser from Thunderbird to Chrom and Edge. Set Chrome back to factory settings. No change. Is there actual another solution as manual zipping the folder?
Support Team posted this 09 July 2017
Could you please create a new private topic and provide more details about the issue (CMS you're using) and attach the problem theme.
Hi, Could you please create a new private topic and provide more details about the issue (CMS you're using) and attach the problem theme. Thank you, Olivia
rgfuller
rgfuller posted this 18 October 2019
How did you solve this? I am having the same problem.
Support Team posted this 22 October 2019
Please try to open Themler through a browser using a link like this
http://127.0.0.1:29958/themler_XXXXXXXXXX/startup/
The exact numbers are visible in Themler Live Preview.
Try different browsers like Safari, Firefox, Chrome and to export.
As a temporary solution, you may copy the theme manually from the folder with themes. Please click Go >> Go to Folder >> type ~/Library and ENTER >> Themler >> hd_data >> cms >> choose CMS and access the themes folder, copy the theme, zip it and install on your hosted website.
Hello, Please try to open Themler through a browser using a link like this http://127.0.0.1:29958/themler_XXXXXXXXXX/startup/ The exact numbers are visible in Themler Live Preview. Try different browsers like Safari, Firefox, Chrome and to export. As a temporary solution, you may copy the theme manually from the folder with themes. Please click Go >> Go to Folder >> type `~/Library` and ENTER >> Themler >> hd_data >> cms >> choose CMS and access the themes folder, copy the theme, zip it and install on your hosted website. Sincerely, Nettie
jesonlee90900
jesonlee90900 posted this 16 November 2025
Difvan has earned a reputation for creating durable and efficient solutions. Whether for work or home projects, their products offer reliability you can count on. The attention to detail and consistent craftsmanship make Difvan a solid choice.
[Difvan][1] has earned a reputation for creating durable and efficient solutions. Whether for work or home projects, their products offer reliability you can count on. The attention to detail and consistent craftsmanship make Difvan a solid choice. [1]: https://www.difvan.com
nicolasagencyseo
nicolasagencyseo posted this 26 November 2025
Shangbo Plastics is a leading manufacturer of premium cable ties, zip ties, and wire ties, delivering high-strength and reliable fastening solutions for global industrial, electrical, automotive, and construction markets. With advanced production technology and strict quality standards, the company is committed to providing durable, efficient, and customizable products for professional applications worldwide.
[Shangbo Plastics is a leading manufacturer of premium cable ties, zip ties, and wire ties,][1] delivering high-strength and reliable fastening solutions for global industrial, electrical, automotive, and construction markets. With advanced production technology and strict quality standards, the company is committed to providing durable, efficient, and customizable products for professional applications worldwide. [1]: https://cabletiesmanufacturer.com/
