Theme customization
kondapanenisiva
kondapanenisiva posted this 29 April 2015
Dear Support.
We wish to purchase few themes from your website. Our query is, there is a footer " Wordpress themes created by aristeer" , But when we purchase and modify themes, this will need to be removed. is it possible we remove this using footer editor in Wordpress or it still same even we use footer editor?.
Your prompt response highly appreciable.
Dear Support. We wish to purchase few themes from your website. Our query is, there is a footer " Wordpress themes created by aristeer" , But when we purchase and modify themes, this will need to be removed. is it possible we remove this using footer editor in Wordpress or it still same even we use footer editor?. Your prompt response highly appreciable.
Support Team posted this 30 April 2015
if you intend to download the .artx project and then export it to certain CMS you may disable the footer notes under File >> Export >> Options >> Footnote in Artisteer.
If you will download the exported theme the text may be removed directly in files. Please let us know what CMS theme (WP, Joomla, etc.) you want to download and we'll described in what file you can remove the footnote text.
Hello, if you intend to download the .artx project and then export it to certain CMS you may disable the footer notes under File >> Export >> Options >> Footnote in Artisteer. If you will download the exported theme the text may be removed directly in files. Please let us know what CMS theme (WP, Joomla, etc.) you want to download and we'll described in what file you can remove the footnote text. regards, Aileen
kondapanenisiva
kondapanenisiva posted this 30 April 2015
We download Wordpress themes.
And also can we able to change theme colours?.
Hi, We download Wordpress themes. And also can we able to change theme colours?. Thank you,
open the ThemeName/footer.php file, find and remove the code block
<span id="art-footnote-links">Powered by <a href="http://wordpress.org/" target="_blank">WordPress</a> and <a href="http://www.artisteer.com/?p=wordpress_themes" target="_blank">WordPress Theme</a> created with Artisteer.</span>
The theme colors in exported WP theme could be changed only manually in the .css files. Please let us know what color you'd like to change (link to the page would be helpful) and we'll help you with it.
Hi, open the `ThemeName/footer.php` file, find and remove the code block <span id="art-footnote-links">Powered by <a href="http://wordpress.org/" target="_blank">WordPress</a> and <a href="http://www.artisteer.com/?p=wordpress_themes" target="_blank">WordPress Theme</a> created with Artisteer.</span> The theme colors in exported WP theme could be changed only manually in the .css files. Please let us know what color you'd like to change (link to the page would be helpful) and we'll help you with it. Regards, Aileen
