horizontal menu effetcs
MercurioWeb WebStudio
MercurioWeb WebStudio posted this 09 December 2016
Hi, how can I create an hover effect like that on the middle page icons of this theme http://www.billionthemes.com/Themes/Preview?id=1894522 or similar, in the horizontal menu?
Support Team posted this 09 December 2016
This effect was created with custom CSS code, you may see the code in details by opening the theme for editing and navigating the Home tab >> Settings >> Additional CSS >> Expand Editor.
Hello, This effect was created with custom CSS code, you may see the code in details by opening the theme for editing and navigating the Home tab >> Settings >> Additional CSS >> Expand Editor. Sincerely, Nettie, BillionDigital Team
there is a effects library?
No, there is no such list of effects, they can be added as a custom code. You can find some possible effects under the Extension tab for some controls.
Hi, No, there is no such list of effects, they can be added as a custom code. You can find some possible effects under the Extension tab for some controls. Sincerely, Hella
How do I insert the effect entered in the custom CSS code for a menu button?
Use the inspect element tool to find out what class name you need to use. Also you can search for some tutorials over the internet.
Use the inspect element tool to find out what class name you need to use. Also you can search for some tutorials over the internet. Sincerely, Hella
