Themler for Joomla: adding a hyperlink to an image shrinks the image...
peter.janssen.steenokkerzeel
peter.janssen.steenokkerzeel posted this 11 December 2016
I'm working on a site right now (still in beta) and the design has more or less finished. Now I'm adding all links to images and so on and I discovered that adding a hyperlink to an image (using the Link option of the image), shrinks my image. It's the only thing I've changed...
I'll add some screen shots of the site (before without URL and after with URL):
Site is http://www.sky-it.be/LesPattesRoyales/
Doesn't seem normal to me that adding a hyperlink would change the size of an image.
Any help on this?
Thanks!
Kind regards,
Peter Janssen
Hi, I'm working on a site right now (still in beta) and the design has more or less finished. Now I'm adding all links to images and so on and I discovered that adding a hyperlink to an image (using the Link option of the image), shrinks my image. It's the only thing I've changed... I'll add some screen shots of the site (before without URL and after with URL): Site is http://www.sky-it.be/LesPattesRoyales/ Doesn't seem normal to me that adding a hyperlink would change the size of an image. Any help on this? Thanks! Kind regards, Peter Janssen
13 Comments
Support Team posted this 13 December 2016
Hello Peter,
I failed to reproduce this issue on Joomla default theme. So it'd be helpful if you provide access to your Joomla admin back end and we'll check the issue with your theme.
Hello Peter, I failed to reproduce this issue on Joomla default theme. So it'd be helpful if you provide access to your Joomla admin back end and we'll check the issue with your theme. regards, Aileen
peter.janssen.steenokkerzeel posted this 13 December 2016
Hope this helps.
Thanks for the effort.
Kind regards,
Peter
P.S. Not sure if this is visible to everyone, if so, please delete this comment. Thanks!
Hope this helps. Thanks for the effort. Kind regards, Peter P.S. Not sure if this is visible to everyone, if so, please delete this comment. Thanks!
Support Team posted this 15 December 2016
Currently this topic is visible by you and our team only.
Please set the height of the image in a little different place:
This should help.
Hi, Currently this topic is visible by you and our team only. Please set the height of the image in a little different place: !image-style-height.png! This should help. Thank you, Olivia
peter.janssen.steenokkerzeel posted this 16 December 2016
Hi, thanks a million, this helps!! Can you tell me why there's a difference between the two height fields?
Anyway, if you can remove the logon details (although I'll remove the user), you can make this topic public. It might be useful to others.
Thanks!
Hi, thanks a million, this helps!! Can you tell me why there's a difference between the two height fields? Anyway, if you can remove the logon details (although I'll remove the user), you can make this topic public. It might be useful to others. Thanks!
Those are a little bit different settings. Now you know where to find it. I have removed the login details and the topic is public now.
Hi, Those are a little bit different settings. Now you know where to find it. I have removed the login details and the topic is public now. Sincerely, Hella
yigop97137
yigop97137 posted this 22 February 2025
강남가라오케는 노래 부르는 걸 좋아하는 사람들에게 딱이에요! 최신곡이 많아서 원하는 노래를 다 부를 수 있었고, 시설도 깔끔해서 만족스러웠어요. 강남에서 가라오케를 찾는다면 강추합니다! 강남가라오케
강남가라오케는 노래 부르는 걸 좋아하는 사람들에게 딱이에요! 최신곡이 많아서 원하는 노래를 다 부를 수 있었고, 시설도 깔끔해서 만족스러웠어요. 강남에서 가라오케를 찾는다면 강추합니다! [강남가라오케][1] [1]: https://gangnam-bestkaraoke.com/
yigop97137
yigop97137 posted this 25 February 2025
I’ve been surfing online more than three hours today, yet I never found any interesting article like yours. It’s pretty worth enough for me. In my opinion, if all webmasters and bloggers made good content as you did, the web will be a lot more useful than ever before. 必利勁香港
I’ve been surfing online more than three hours today, yet I never found any interesting article like yours. It’s pretty worth enough for me. In my opinion, if all webmasters and bloggers made good content as you did, the web will be a lot more useful than ever before. [必利勁香港][1] [1]: https://www.priligy-hk.cn/
michaelarringtony
michaelarringtony posted this 28 February 2025
Check the editor’s image settings after adding the link—look for a size PolyTrack toggle or reset option. If it’s custom code, share the relevant HTML snippet, and I can pinpoint it.
Check the editor’s image settings after adding the link—look for a size [PolyTrack][1] toggle or reset option. If it’s custom code, share the relevant HTML snippet, and I can pinpoint it. [1]: https://polytrack.org/
yigop97137
yigop97137 posted this 05 March 2025
Thank you for very usefull information.. 犀利士香港
Thank you for very usefull information.. [犀利士香港][1] [1]: https://www.cialis-hk.cn/
yigop97137
yigop97137 posted this 06 May 2025
This is a great inspiring article.I am pretty much pleased with your good work.You put really very helpful information vault opener nyt crossword
This is a great inspiring article.I am pretty much pleased with your good work.You put really very helpful information [vault opener nyt crossword][1] [1]: https://www.wispwillow.com/games/vault-opener-nyt-crossword-crack-the-code
yigop97137
yigop97137 posted this 21 May 2025
I am very much pleased with the contents you have mentioned. I wanted to thank you for this great article. moon chocolate bar
I am very much pleased with the contents you have mentioned. I wanted to thank you for this great article. [moon chocolate bar][1] [1]: https://meridian-puff.com/product-category/moon-chocolate-bar/
yigop97137
yigop97137 posted this 10 June 2025
You have a good point here!I totally agree with what you have said!!Thanks for sharing your views…hope more people will read this article!!! laser247 ID
You have a good point here!I totally agree with what you have said!!Thanks for sharing your views…hope more people will read this article!!! [laser247 ID][1] [1]: https://www.laser24x7.online/
yigop97137
yigop97137 posted this 22 June 2025
Good artcile, but it would be better if in future you can share more about this subject. Keep posting. Play99Exch ID
Good artcile, but it would be better if in future you can share more about this subject. Keep posting. [Play99Exch ID][1] [1]: https://www.play99exch.co/
