CMS-Code
info1496
info1496 posted this 15 December 2016
I am trying to add extra fields to the user profiles and I don`t want to use a plugin for it.
I found several codes for that but they all didn´t add the fields when added to CMS Code field in Themler.
I now tried a plugin to add code to the functions.php and it turns out the code does work...only not through the Themler field
Example Code:
function modify_contact_methods($profile_fields) {
// Add new fields
$profile_fields['twitter'] = 'Twitter Username';
$profile_fields['facebook'] = 'Facebook URL';
$profile_fields['gplus'] = 'Google+ URL';
return $profile_fields;
add_filter('user_contactmethods', 'modify_contact_methods');
I want to get rid of the additional plugin again and have that work through themler. Any ideas on that?
Thanks in advance!
Hi, I am trying to add extra fields to the user profiles and I don`t want to use a plugin for it. I found several codes for that but they all didn´t add the fields when added to CMS Code field in Themler. I now tried a plugin to add code to the functions.php and it turns out the code does work...only not through the Themler field Example Code: function modify_contact_methods($profile_fields) { // Add new fields $profile_fields['twitter'] = 'Twitter Username'; $profile_fields['facebook'] = 'Facebook URL'; $profile_fields['gplus'] = 'Google+ URL'; return $profile_fields; } add_filter('user_contactmethods', 'modify_contact_methods'); I want to get rid of the additional plugin again and have that work through themler. Any ideas on that? Thanks in advance!
9 Comments
The CMS Code Themler function (in Settings) adds the code to the functions-additional.php file. Currently the code is not working because you're trying to make changes to the admin panel settings. The next Themler update will contain the fix for this issue.
Themler Team
Hi, The *CMS Code* Themler function (in Settings) adds the code to the `functions-additional.php` file. Currently the code is not working because you're trying to make changes to the admin panel settings. The next Themler update will contain the fix for this issue. Thank you, Themler Team
kevindaniel0102
kevindaniel0102 posted this 27 September 2023
To add extra fields to user profiles without using a plugin in Themler, you can modify the functions.php file of your theme. However, adding code directly to the CMS Code field in Themler might not work as expected.
Here’s an alternative approach you can try:
Open the functions.php file of your theme.
Add the following code to the file:
// Add new fields
Save the changes to the rooftop snipers functions.php file.
By adding this code to the functions.php file, you should be able to add extra fields to user profiles without relying on an additional plugin.
Please note that modifying theme files directly can have implications for future updates or compatibility with other plugins. It’s recommended to create a child theme and make modifications there instead.
To add extra fields to user profiles without using a plugin in Themler, you can modify the functions.php file of your theme. However, adding code directly to the CMS Code field in Themler might not work as expected. Here’s an alternative approach you can try: Open the functions.php file of your theme. Add the following code to the file: function modify_contact_methods($profile_fields) { // Add new fields $profile_fields['twitter'] = 'Twitter Username'; $profile_fields['facebook'] = 'Facebook URL'; $profile_fields['gplus'] = 'Google+ URL'; return $profile_fields; } add_filter('user_contactmethods', 'modify_contact_methods'); Save the changes to the [rooftop snipers][1] functions.php file. By adding this code to the functions.php file, you should be able to add extra fields to user profiles without relying on an additional plugin. Please note that modifying theme files directly can have implications for future updates or compatibility with other plugins. It’s recommended to create a child theme and make modifications there instead. [1]: https://rooftopsnipers.io
montanaroy4
montanaroy4 posted this 15 August 2024
Solara Windows does not yet have the capability to bypass Byfron/Hyperion, so it's advisable to use alternate accounts for Roblox exploitation. While there are many Roblox executors available, Fluxus website stands out due to its intuitive and user-friendly interface, which makes it popular among Roblox gamers. To use Fluxus, you'll need to download and install the executor on both your phone and PC, then obtain a key.
[Solara Windows][1] does not yet have the capability to bypass Byfron/Hyperion, so it's advisable to use alternate accounts for Roblox exploitation. While there are many Roblox executors available, Fluxus [website][2] stands out due to its intuitive and user-friendly interface, which makes it popular among Roblox gamers. To use Fluxus, you'll need to download and install the executor on both your phone and PC, then obtain a key. [1]: https://solaraexecutor.com/ [2]: https://fluxus.mobi/
sardarloga
sardarloga posted this 22 October 2024
The Addrom Bypass is a key infrastructure project designed to streamline traffic flow and improve connectivity in the area. It facilitates smoother transportation for both local residents and commercial vehicles, reducing congestion and travel time. This development boosts regional economic growth and enhances logistics efficiency. https://addrombypass.app/
NovaLindgren56
NovaLindgren56 posted this 23 October 2024
Hi, while you are checking for cms errors, if you encounter any difficulties or run out of ideas, take some time to play Raft Wars, it will help you regain energy immediately and have more interesting ideas.
Hi, while you are checking for cms errors, if you encounter any difficulties or run out of ideas, take some time to play [Raft Wars](https://raftwar.io), it will help you regain energy immediately and have more interesting ideas.
carxstreet56892
carxstreet56892 posted this 29 October 2024
CarX Street Drive plunges players into the thrilling world of street racing, offering realistic car physics, customizable vehicles, and an expansive open world. With stunning visuals and intense racing challenges, players can test their skills in high-speed chases, navigate detailed city streets, and explore a dynamic, ever-evolving racing universe.See more https://carxstreetdrive.com/
pvcmloza
pvcmloza posted this 18 December 2024
For users who want to try out games before making a purchase, some Game Vault apps allow access to in-app game trials or demos. These trials are often time-limited versions of the full game that let users experience the gameplay and features without committing to a purchase. This is particularly helpful for gamers who are on the fence about a specific title, as it provides a risk-free way to assess whether the game meets their expectations click for free download. The app may also help users discover promotional trials or beta versions of upcoming games, offering early access before the official release.
For users who want to try out games before making a purchase, some Game Vault apps allow access to in-app game trials or demos. These trials are often time-limited versions of the full game that let users experience the gameplay and features without committing to a purchase. This is particularly helpful for gamers who are on the fence about a specific title, as it provides a risk-free way to assess whether the game meets their expectations [click for free download][1]. The app may also help users discover promotional trials or beta versions of upcoming games, offering early access before the official release. [1]: https://gamevaultapk.net/game-vault-777-for-pc/
abdx2324
abdx2324 posted this 07 October 2025
Love this roundup if anyone’s looking for advanced tips check out my Stick War Legacy strategy guide for unit combos and micromanagement tricks anchor text Stick War Legacy strategy guide https://stickwarlegacyapp.com/
philljones0022
philljones0022 posted this 11 March 2026
Krnl Executor Ultima Version brings upgraded performance and enhanced support for running custom scripts smoothly. It includes improvements that make script execution faster and more stable. Many users choose the Ultima Version of Krnl Executor to access the newest updates and better functionality.
Krnl Executor [Ultima Version][1] brings upgraded performance and enhanced support for running custom scripts smoothly. It includes improvements that make script execution faster and more stable. Many users choose the Ultima Version of Krnl Executor to access the newest updates and better functionality. [1]: https://krnlexcutor.org/
