I want to insert a blog (homepage template). Isn't this feature available anymore?
Kind regards,
Hi, I want to insert a blog (homepage template). Isn't this feature available anymore? Kind regards,
Kind regards,
Hi, I want to insert a blog (homepage template). Isn't this feature available anymore? Kind regards,Hi Anneke, if i am not mistaken, the new themler version has a different way to show posts and blog pages..
What you need to do is go to your home template, and than go to "sidebars", its an orange button on the left panel, and press it.
Now you will see a button to "Show on template" , and if you enable it, and than refresh themler, you should see the cms content, or blog posts..
I hope you understood my method, if you need anything else i will be happy to help :)
Hi Anneke, if i am not mistaken, the new themler version has a different way to show posts and blog pages.. What you need to do is go to your home template, and than go to "sidebars", its an orange button on the left panel, and press it. Now you will see a button to "Show on template" , and if you enable it, and than refresh themler, you should see the cms content, or blog posts.. I hope you understood my method, if you need anything else i will be happy to help :)Believe it is inside Theme options in WP backend
You make new custom template for "Home". And chose this in Theme Options (not WP settings).
The Shaul's suggestion is very close.
How would I do this in the new Themler layout there isn't a CMS Content option as displayed in number 3 in the image you show.
I know this must be easy but I deleted my post content on the post template and for the life can't figure out how to ad it again.
Under the Design tab there is an option to enable CMS Content.
