Set the absolute position for each button and 0px to the Bottom value.
Привет, Установите абсолютное положение для каждой кнопки и 0px к нижнему значению. С уважением, Hella
Another question. How to fix the icon?
Also not fixed.
Добрый день,
Не совсем поняла ваш пследний вопрос. Можете прикрепить картинку и детальнее описать проблему?
How to fix the icons?
Why don't you want to use one general image?
The alternative solution is Container with fixed width and height. Inside it you can position images with absolute positioning using Positioning dialog. But this solution is not good for responsive. The single image is better.
Themler Team
Each image is a separate button, which when pressed, will open another section. One image just will not work.
Each image is a separate button, which when pressed, will open another section. One image just will not work.Hi,
This is not really good layout, especially for responsive.
Нow would you do it on simple html page without Themler?
Currently I have only one idea with Container with sized size and elements inside it with absolute position. Or imagemap. But imagemap requires fixed size of the image too.
Themler Team
