joomla menu
foffi.alessandro
foffi.alessandro posted this 17 December 2016
I got a problem with joomla menu. I got two menu one for the homepage and the other one for the pages. Since two day ago every thing was ok but now I got under the menu of the pages "Please add a menu module in the 'hmenu' position".
I attach a screenshot to let you understand better.
Thank you so much.
Hi, I got a problem with joomla menu. I got two menu one for the homepage and the other one for the pages. Since two day ago every thing was ok but now I got under the menu of the pages "Please add a menu module in the 'hmenu' position". I attach a screenshot to let you understand better. Thank you so much.
I'd recommend that in your particular case you create two different "Headers" with different menus and display one of then at Home page and the other - on the rest pages.
The idea is:
1.enable Header area on the Home template and disable on other templates , e.g. on Page template
2.set up the Header area in the way you need;
3.open the Page template (where the Header is disabled)
4.add empty Section control at the top of Template. It will be used as header there
5.add Logo control and other necessary controls to this section. And add another menu control, for example Top Menu control
6.add Menu type module to this position in Joomla admin back end. Here is sample result
Hello, I'd recommend that in your particular case you create two different "Headers" with different menus and display one of then at Home page and the other - on the rest pages. The idea is: 1.enable Header area on the Home template and disable on other templates , e.g. on Page template 2.set up the Header area in the way you need; 3.open the Page template (where the Header is disabled) 4.add empty Section control at the top of Template. It will be used as header there !AddSection.png! 5.add Logo control and other necessary controls to this section. And add another menu control, for example Top Menu control !AddTMenu.png! 6.add Menu type module to this position in Joomla admin back end. Here is sample result !NewMenu.png! Regards, Aileen
foffi.alessandro
foffi.alessandro posted this 19 December 2016
Perfect I will follow your suggestion.
Thank you so much
Perfect I will follow your suggestion. Thank you so much
You are welcome. Let us know if you need our further help.
You are welcome. Let us know if you need our further help. Sincerely, Hella
