Themler crashes with the above message while designing joomla site. Could you help.
Themler crashes with the above message while designing joomla site. Could you help.Could you please try the following:
1. Clear cache:
http://answers.themler.com/articles/8713/error-sorry-an-error-has-occurred-please-clear-your-browser-cache
2. Clear AppCache. Use Chrome browser for this:
http://answers.themler.com/articles/14063/how-to-clear-appcache
3. If the issue persists, please try disabling third-party plugins and components and let us know if the issue is still present.
j'ai le même problème !!! j'ai fais toutes les manipulations que vous demandé mais ca ne règle pas le problème ! je ne peux pas modifier mon template ! je dois faire quoi ??
j'ai le même problème !!! j'ai fais toutes les manipulations que vous demandé mais ca ne règle pas le problème ! je ne peux pas modifier mon template ! je dois faire quoi ??Hi,
Could you please create a new private ticket and explain your issue in some more detail there.
We would need a temp access to your Joomla back-end as well in order to reproduce the issue.
Ivan
Use firefox developer edition for that. I had the same issue with all other browsers but today is the second day im working without having to clear cache every one minute
